我已将 PTA14 配置为 ADC_1,但 Siul2_Port_Ip_Cfg.c 没有生成代码。
{ .base = IP_SIUL2, .pinPortidx = 12u, .mux = PORT_MUX_ALT3, .safeMode = PORT_SAFE_MODE_DISABLED, .inputFilter = PORT_INPUT_FILTER_DISABLED, .pullConfig = PORT_INTERNAL_PULL_NOT_ENABLED, .pullKeep = PORT_PULL_KEEP_DISABLED, .invert = PORT_INVERT_DISABLED, .inputBuffer = PORT_INPUT_BUFFER_ENABLED, .outputBuffer = PORT_OUTPUT_BUFFER_DISABLED, .adcInterleaves = { MUX_MODE_NOT_AVAILABLE, MUX_MODE_NOT_AVAILABLE }, .inputMuxReg = { 1u }, .inputMux = { PORT_INPUT_MUX_ALT2, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT }, }, { .base = IP_SIUL2, .pinPortIdx = 16u, .mux = PORT_MUX_AS_GPIO, .safeMode = PORT_SAFE_MODE_DISABLED, .inputFilter = PORT_INPUT_FILTER_DISABLED, .pullConfig = PORT_INTERNAL_PULL_NOT_ENABLED, .pullKeep = PORT_PULL_KEEP_DISABLED, .invert = PORT_INVERT_DISABLED, .inputBuffer = PORT_INPUT_BUFFER_ENABLED, .outputBuffer = PORT_OUTPUT_BUFFER_DISABLED, .adcInterleaves = { MUX_MODE_NOT_AVAILABLE, MUX_MODE_NOT_AVAILABLE }, .inputMux = { PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT, PORT_INPUT_MUX_NO_INIT }, }, |
1975个成员聚集在这个小组
36593 浏览 0 评论
6040 浏览 1 评论
6264 浏览 1 评论
6951 浏览 0 评论
4331 浏览 0 评论
742浏览 2评论
721浏览 2评论
733浏览 2评论
810浏览 2评论
928浏览 2评论
GMT+8, 2025-3-6 11:28 , Processed in 1.141018 second(s), Total 75, Slave 59 queries .
