我重新安装了 ESP-IDF,但无法将目标更改为 esp32s2。
C:\esp\projects\hello_world>idf.py set-target esp32s2 Adding "set-target"'s dependency "fullclean" to list of commands with default set of options. Executing action: fullclean Executing action: set-target Set Target to: esp32s2, new sdkconfig created. Existing sdkconfig renamed to sdkconfig.old. Running cmake in directory c:\esp\projects\hello_world\build Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32s2 -DCCACHE_ENABLE=1 c:\esp\projects\hello_world"... -- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.29.2.windows.3") CMake Error at C:/esp/esp-idf/tools/cmake/targets.cmake:19 (message): IDF_TARGET in CMake cache does not match IDF_TARGET environment variable. To change the target, clear the build directory and sdkconfig file, and build the project again Call Stack (most recent call first): C:/esp/esp-idf/tools/cmake/project.cmake:35 (__target_init) CMakeLists.txt:5 (include) -- Configuring incomplete, errors occurred! cmake failed with exit code 1 构建项目会成功但闪烁失败,因为我有一个 esp32s2 芯片。 A fatal error occurred: This chip is ESP32-S2 not ESP32. Wrong --chip argument? CMake Error at run_serial_tool.cmake:50 (message): C:/esp/.espressif/python_env/idf4.3_py3.9_env/Scripts/python.exe C:/esp/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32 failed 我的环境是最新的Python,最新的git,今天的ESP-IDF master分支,esp-idf-tools-setup-2.3。 git clone --recursive https://github.com/espressif/esp-idf.git 谁能告诉我如何创建一个有效的 ESP32S2 构建环境? |
1934个成员聚集在这个小组
36421 浏览 0 评论
4909 浏览 1 评论
6109 浏览 1 评论
6819 浏览 0 评论
4249 浏览 0 评论
649浏览 2评论
644浏览 2评论
646浏览 2评论
730浏览 2评论
846浏览 2评论
GMT+8, 2024-12-25 04:29 , Processed in 0.862843 second(s), Total 42, Slave 37 queries .
