我有一个 ESP-Prog 连接到 TTGO T8 ESP32 板(仅限 JTAG 接口)。一旦我初始化 sd 卡,我就无法调试应用程序。
以下是有效的日志(无 SD 卡): $ openocd -f interface/ftdi/esp32_devkitj_v1.cfg -f target/esp32.cfg Open On-Chip Debugger v0.11.0-esp32-20221026 (2022-10-26-14:47) Licensed under GNU GPL v2 For bug reports, read adapter speed: 20000 kHz Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling" Info : clock speed 20000 kHz Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1) Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1) Info : starting gdb server for esp32.cpu0 on 3333 Info : Listening on port 3333 for gdb connections Info : [esp32.cpu0] Debug controller was reset. Info : [esp32.cpu0] Core was reset. Info : [esp32.cpu1] Debug controller was reset. Info : [esp32.cpu1] Core was reset. Info : [esp32.cpu0] Target halted, PC=0x4008C192, debug_reason=00000000 Info : [esp32.cpu0] Reset cause (1) - (Power on reset) Info : [esp32.cpu1] Target halted, PC=0x4008C192, debug_reason=00000000 Info : [esp32.cpu1] Reset cause (14) - (CPU1 reset by CPU0) |
2016个成员聚集在这个小组
36706 浏览 0 评论
6201 浏览 1 评论
6432 浏览 1 评论
7044 浏览 0 评论
4441 浏览 0 评论
895浏览 2评论
1008浏览 2评论
1170浏览 2评论
如何读取MPC5777C单片机中的pwm信号?有没有应用示例或代码示例?
506浏览 2评论
1607浏览 2评论
GMT+8, 2025-4-30 15:57 , Processed in 0.819979 second(s), Total 74, Slave 58 queries .
