我已经在带有 ESP32-WROOM32-UE 模块的两块 PCB 上加载了触摸示例“touch_pad_read”。
在PCB 上一切正常,但在第二块 PCB 上触摸板 6(PIN 14,T6)一直读取 0。?我检查了 PIN 14 是否错误地连接到地平面,但发现情况并非如此。猜猜第二块 PCB 上的问题是什么?有没有可能只有模块的一个触摸针不工作,或者是一些配置问题等?我 正在使用 ESP-IDF V4.4.2。 在 PCB1 上 读取是可以的: [size=85%]T0:[1605,1605] T1:[1101,1102] T2:[1571,1571] T3:[1558,1558] T4: [1686,1686] T5:[1677,1677] T6:[1762,1762] T7:[1781,1781] T8:[1823,1820] T9:[1871,1867] T0:[1606,1606] T1:[1103,1103] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1678,1678] T6:[1761,1762] T7 :[1781,1781] T8:[1822,1816] T9:[1869,1865] T0 :[1605,1605] T1:[1102,1103] T2:[1571,1571] T3:[1557,1557] T4:[1686,1686] T5:[1677,1677] T6:[1761,1761] T7:[1780,1780] T8:[1810,1816] T9:[1868,1867] T0 ] T1:[1103,1103] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1678,1678] T6:[1761,1761] T7:[1781,1781] T8:[1822,1816] T9:[1851,1860] T0 :[1606,1605] T1:[1103,1102] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686 ] T5:[1677,1677] T6:[1762,1762] T7:[1781,1780] T8:[1822,1814] T9:[1871,1862] 在 PCB2 上 读取,在 T6 中读取 0: [size=85%]T0:[1605,1605] T1:[1101,1102] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1677,1677] T6:[0,0] T7 :[1781,1781] T8:[1823,1820] T9:[1871,1867] T0 :[1606,1606] T1:[1103,1103] T2:[1571,1571] T3:[1558,1558 ] T4:[1686,1686] T5:[1678,1678] T6:[0,0] T7:[1781,1781] T8:[1822,1816] T9:[1869,1865] T0 ,1605] T1:[1102,1103] T2:[1571,1571] T3:[1557,1557] T4:[1686,1686] T5:[1677,1677] T6:[0,0] T7:[1780, 1780] T8:[1810,1816] T9:[1868,1867] T0 :[1606,1606] T1:[1103,1103] T2:[1571,1571] T3:[1558,1558] T4:[ 1686,1686] T5:[1678,1678] T6:[0,0] T7:[1781,1781] T8:[1822,1816] T9:[1851,1860] T0 1606,1605] T1 :[1103,1102] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1677,1677] T6:[0,0] T7:[1781,1780] T8 :[1822,1814] T9:[1871,1862] |
1980个成员聚集在这个小组
36625 浏览 0 评论
6111 浏览 1 评论
6309 浏览 1 评论
6972 浏览 0 评论
4345 浏览 0 评论
759浏览 2评论
735浏览 2评论
755浏览 2评论
831浏览 2评论
945浏览 2评论
GMT+8, 2025-3-18 13:36 , Processed in 0.481356 second(s), Total 43, Slave 37 queries .
