如何使用 ESP32-CAM 的 ESPtool 恢复出厂设置、擦除 EEPROM 和修复 Bootloader?
我可以用 esptool 为 ESP32 做这件事,但不能为 ESP32-CAM 做。 我尝试通过 Arduino UNO、FTDI 和 ESP32-CAM-MB 连接 ESP32-CAM。 Arduino:1.8.19 (Linux),开发板:“ESP32 Wrover 模块,巨大的应用程序(3MB 无 OTA/1MB SPIFFS),QIO,40MHz,115200,无” henkoegema @ HP-Pavilion ~ => esptool.py --chip esp32 --port /dev/ttyUSB0 erase_flash esptool.py v4.5.1 Serial port /dev/ttyUSB0 Connecting...................................... A fatal error occurred: Failed to connect to ESP32: No serial data received. For troubleshooting steps visit: henkoegema @ HP-Pavilion ~ => esptool.py --chip esp32 --port /dev/ttyUSB0 erase_flash esptool.py v4.5.1 Serial port /dev/ttyUSB0 Connecting...................................... A fatal error occurred: Failed to connect to ESP32: No serial data received. For troubleshooting steps visit: henkoegema @ HP-Pavilion ~ => esptool.py --chip esp32 --port /dev/ttyUSB0 erase_flash esptool.py v4.5.1 Serial port /dev/ttyUSB0 Connecting...................................... A fatal error occurred: Failed to connect to ESP32: No serial data received. For troubleshooting steps visit: henkoegema @ HP-Pavilion ~ => esptool.py --chip esp32 --port /dev/ttyUSB0 erase_flash esptool.py v4.5.1 Serial port /dev/ttyUSB0 Connecting...................................... A fatal error occurred: Failed to connect to ESP32: No serial data received. For troubleshooting steps visit: henkoegema @ HP-Pavilion ~ => esptool.py v3.0-dev Serial port /dev/ttyACM0 Connecting........_____....._____....._____....._____....._____....._____.....____An error occurred while uploading the sketch _ A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header 我注意到闪光灯一直亮着(光强度低) |
1963个成员聚集在这个小组
36571 浏览 0 评论
5974 浏览 1 评论
6244 浏览 1 评论
6937 浏览 0 评论
4325 浏览 0 评论
738浏览 2评论
709浏览 2评论
727浏览 2评论
802浏览 2评论
924浏览 2评论
GMT+8, 2025-2-24 02:03 , Processed in 0.829527 second(s), Total 41, Slave 36 queries .
