[yw079@localhost build_t2080rdb-64b]$ bitbake fsl-image-minimal
Traceback(最近调用最后): 文件“/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/ bin/bitbake”,第 31 行,在 导入 bb 文件“/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/__init__.py”,第 77 行,在 from bb import fetch2 as fetch File "/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py" , 第 37 行,在 import bb.persist_data, bb.utils File "/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/persist_data.py ",第 35 行,在 from pysqlite2 import dbapi2 as sqlite3 ImportError: No module named pysqlite2 /opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/event.py:118: RuntimeWarning: 在处理从 bb 的绝对导入时找不到父模块 'bb' .msg import BBLogFormatter atexit._run_exitfuncs 中的错误: Traceback(最近调用最后一次): 文件“/usr/local/lib/python2.7/atexit.py”,第 24 行,在 _run_exitfuncs func(*targs, **kargs) 文件“/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/event.py”,第 118 行,在 print_ui_queue from bb.msg import BBLogFormatter File“/ opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/__init__.py”,第 77 行,在 fetch 文件“/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py”,第 37 行,在 import bb.persist_data 中, bb.utils 文件“/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/persist_data.py”,第 35 行,在 from pysqlite2 import dbapi2作为 sqlite3 ImportError: sys.exitfunc 中 没有名为 pysqlite2 的模块错误: Traceback(最近一次调用):文件“/usr/local/lib/python2.7/atexit.py”,第 24 行,在 _run_exitfuncs func(*targs, **kargs)文件“/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/event.py”,第 118 行,在 print_ui_queue from bb.msg import BBLogFormatter 文件“/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/__init__.py”,第 77 行,在 from bb import fetch2 as fetch File “/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py”,第 37 行,在 import bb.persist_data, bb .utils 文件“/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/persist_data.py”,第 35 行,在 from pysqlite2 import dbapi2 as sqlite3 导入错误:没有名为 pysqlite2 的模块 [yw079@localhost build_t2080rdb-64b]$ |
1866个成员聚集在这个小组
36179 浏览 0 评论
4282 浏览 0 评论
5912 浏览 1 评论
6655 浏览 0 评论
4105 浏览 0 评论
532浏览 2评论
524浏览 2评论
517浏览 2评论
598浏览 2评论
649浏览 2评论
GMT+8, 2024-9-20 20:44 , Processed in 0.707898 second(s), Total 42, Slave 37 queries .
