我安装了鲁班猫to Ubuntu 22.04.2 LTS (GNU/Linux 4.19.232 aarch64)
这个系统已经安装好了python3.10
但是没有安装pip,为了方便以后的开发安装python-pip
cat@lubancat:~$ sudo apt install python3-pip
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages were automatically installed and are no longer required:
accountsservice-ubuntu-schemas activity-log-manager apg aptdaemon aptdaemon-data
cracklib-runtime gedit gedit-common geoclue-2.0 gir1.2-accountsservice-1.0 gir1.2-adw-1
gir1.2-gck-1 gir1.2-gcr-3 gir1.2-gdesktopenums-3.0 gir1.2-gdm-1.0 gir1.2-geoclue-2.0
gir1.2-gnomebluetooth-3.0 gir1.2-gnomedesktop-3.0 gir1.2-graphene-1.0 gir1.2-gtk-4.0
gir1.2-gtksource-4 gir1.2-gweather-3.0 gir1.2-javascriptcoregtk-4.0 gir1.2-json-1.0
gir1.2-mutter-10 gir1.2-nma-1.0 gir1.2-peas-1.0 gir1.2-rsvg-2.0 gir1.2-soup-2.4
gir1.2-upowerglib-1.0 gir1.2-vte-2.91 gkbd-capplet gnome-bluetooth-3-common
gnome-bluetooth-common gnome-control-center-data gnome-control-center-faces gnome-menus
gnome-remote-desktop gnome-settings-daemon gnome-shell-common gsfonts iio-sensor-proxy
imagemagick-6-common language-selector-gnome libabsl20210324 libadwaita-1-0 libcolord-gtk1
libcrack2 libdca0 libde265-0 libdee-1.0-4 libdjvulibre-text libdjvulibre21
libebackend-1.2-10 libebook-1.2-20 libebook-contacts-1.2-3 libedata-book-1.2-26
libedata-cal-2.0-1 libfaad2 libfftw3-double3 libfluidsynth3 libfreeaptx0
libfreerdp-client2-2 libfreerdp-server2-2 libfreerdp2-2 libgdm1 libgeoclue-2-0
libgeocode-glib0 libgeonames-common libgeonames0 libgjs0g libgnome-autoar-0-0
libgnome-bluetooth-3.0-13 libgnome-bluetooth13 libgnome-menu-3-0 libgnomekbd8 libgsound0
libgspell-1-2 libgspell-1-common libgssdp-1.2-0 libgtksourceview-4-0
libgtksourceview-4-common libgupnp-1.2-1 libgupnp-av-1.0-3 libgupnp-igd-1.0-4
libgweather-3-16 libgweather-common libheif1 libilmbase25 libinstpatch-1.0-2 libjxr-tools
libjxr0 libkate1 liblqr-1-0 libltc11 libmagickcore-6.q16-6 libmagickcore-6.q16-6-extra
libmagickwand-6.q16-6 libmediaart-2.0-0 libmjpegutils-2.1-0 libmodplug1 libmozjs-102-0
libmpcdec6 libmpeg2encpp-2.1-0 libmplex2-2.1-0 libmutter-10-0 libnice10 libopenexr25
libopenh264-6 libopenni2-0 libpeas-1.0-0 libpeas-common libphonenumber8 libprotobuf23
libpulsedsp libpwquality-common libpwquality1 libqrencode4 libqt5multimedia5
libqt5multimediaquick5 libqt5multimediawidgets5 libqt5qml5 libqt5qmlmodels5
libqt5qmlworkerscript5 libqt5quick5 librest-0.7-0 librygel-core-2.6-2 librygel-db-2.6-2
librygel-renderer-2.6-2 librygel-server-2.6-2 libsoundtouch1 libsoup-gnome2.4-1 libspandsp2
libspeexdsp1 libsrtp2-1 libtimezonemap-data libtimezonemap1 libtumbler-1-0
libunity-control-center1 libvncserver1 libvo-aacenc0 libvo-amrwbenc0
libwhoopsie-preferences0 libwildmidi2 libwinpr2-2 libwmflite-0.2-7 libxcb-res0 libxcb-xv0
libxcvt0 libzbar0 libzeitgeist-2.0-0 libzxingcore1 mutter-common power-profiles-daemon
pulseaudio-utils python3-aptdaemon python3-aptdaemon.gtk3widgets python3-chardet
python3-defer python3-macaroonbakery python3-nacl python3-protobuf python3-pymacaroons
python3-requests python3-rfc3339 python3-tz qml-module-qt-labs-folderlistmodel
qml-module-qtmultimedia qml-module-qtquick2 switcheroo-control timgm6mb-soundfont
tumbler-common ubuntu-wallpapers ubuntu-wallpapers-jammy whoopsie whoopsie-preferences
xwayland yaru-theme-gnome-shell zeitgeist-core zenity-common
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
binutils binutils-aarch64-linux-gnu binutils-common build-essential dpkg-dev fakeroot g++
g++-11 gcc gcc-11 javascript-common libalgorithm-diff-perl libalgorithm-diff-xs-perl
libalgorithm-merge-perl libasan6 libbinutils libcc1-0 libctf-nobfd0 libctf0 libexpat1-dev
libfakeroot libgcc-11-dev libhwasan0 libitm1 libjs-jquery libjs-sphinxdoc libjs-underscore
liblsan0 libpython3-dev libpython3.10 libpython3.10-dev libpython3.10-minimal
libpython3.10-stdlib libstdc++-11-dev libtsan0 libubsan1 lto-disabled-list make patch
python3-dev python3-setuptools python3-wheel python3.10 python3.10-dev python3.10-minimal
Suggested packages:
binutils-doc debian-keyring gcc-11-doc gcc-multilib autoconf automake libtool flex bison
gcc-doc gcc-11-locales apache2 | lighttpd | httpd libstdc++-11-doc make-doc ed
diffutils-doc python-setuptools-doc python3.10-venv python3.10-doc binfmt-support
The following NEW packages will be installed:
liblsan0 libpython3-dev libpython3.10-dev libstdc++-11-dev libtsan0 libubsan1
lto-disabled-list make patch python3-dev python3-pip python3-setuptools python3-wheel
python3.10-dev
The following packages will be upgraded:
libpython3.10 libpython3.10-minimal libpython3.10-stdlib python3.10 python3.10-minimal
5 upgraded, 41 newly installed, 0 to remove and 56 not upgraded.
Need to get 62.1 MB of archives.
After this operation, 185 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http:
Get:2 http:
Get:3 http:
Get:4 http:
Get:5 http:
Get:6 http:
Get:7 http:
Get:8 http:
Get:9 http:
Get:10 http:
Get:11 http:
Get:12 http:
Get:13 http:
Get:14 http:
Get:15 http:
Get:16 http:
Get:17 http:
Get:18 http:
Get:19 http:
Get:20 http:
Get:21 http:
Get:22 http:
Get:23 http:
Get:24 http:
Get:25 http:
Get:26 http:
Get:27 http:
Get:28 http:
Get:29 http:
Get:30 http:
Get:31 http:
Get:32 http:
Get:33 http:
Get:34 http:
Get:35 http:
Get:36 http:
Get:37 http:
Get:38 http:
Get:39 http:
Get:40 http:
Get:41 http:
Get:42 http:
Get:43 http:
Get:44 http:
Get:45 http:
Get:46 http:
Fetched 62.1 MB in 6s (11.2 MB/s)
Extracting templates from packages: 100%
(Reading database ... 121795 files and directories currently installed.)
Preparing to unpack .../00-libpython3.10_3.10.6-1~22.04.2ubuntu1_arm64.deb ...
Unpacking libpython3.10:arm64 (3.10.6-1~22.04.2ubuntu1) over (3.10.6-1~22.04.2) ...
Preparing to unpack .../01-python3.10_3.10.6-1~22.04.2ubuntu1_arm64.deb ...
Unpacking python3.10 (3.10.6-1~22.04.2ubuntu1) over (3.10.6-1~22.04.2) ...
Preparing to unpack .../02-libpython3.10-stdlib_3.10.6-1~22.04.2ubuntu1_arm64.deb ...
Unpacking libpython3.10-stdlib:arm64 (3.10.6-1~22.04.2ubuntu1) over (3.10.6-1~22.04.2) ...
Preparing to unpack .../03-python3.10-minimal_3.10.6-1~22.04.2ubuntu1_arm64.deb ...
Unpacking python3.10-minimal (3.10.6-1~22.04.2ubuntu1) over (3.10.6-1~22.04.2) ...
Preparing to unpack .../04-libpython3.10-minimal_3.10.6-1~22.04.2ubuntu1_arm64.deb ...
Unpacking libpython3.10-minimal:arm64 (3.10.6-1~22.04.2ubuntu1) over (3.10.6-1~22.04.2) ...
Selecting previously unselected package binutils-common:arm64.
Preparing to unpack .../05-binutils-common_2.38-4ubuntu2.1_arm64.deb ...
Unpacking binutils-common:arm64 (2.38-4ubuntu2.1) ...
Selecting previously unselected package libbinutils:arm64.
Preparing to unpack .../06-libbinutils_2.38-4ubuntu2.1_arm64.deb ...
Unpacking libbinutils:arm64 (2.38-4ubuntu2.1) ...
Selecting previously unselected package libctf-nobfd0:arm64.
Preparing to unpack .../07-libctf-nobfd0_2.38-4ubuntu2.1_arm64.deb ...
Unpacking libctf-nobfd0:arm64 (2.38-4ubuntu2.1) ...
Selecting previously unselected package libctf0:arm64.
Preparing to unpack .../08-libctf0_2.38-4ubuntu2.1_arm64.deb ...
Unpacking libctf0:arm64 (2.38-4ubuntu2.1) ...
Selecting previously unselected package binutils-aarch64-linux-gnu.
Preparing to unpack .../09-binutils-aarch64-linux-gnu_2.38-4ubuntu2.1_arm64.deb ...
Unpacking binutils-aarch64-linux-gnu (2.38-4ubuntu2.1) ...
Selecting previously unselected package binutils.
Preparing to unpack .../10-binutils_2.38-4ubuntu2.1_arm64.deb ...
Unpacking binutils (2.38-4ubuntu2.1) ...
Selecting previously unselected package libcc1-0:arm64.
Preparing to unpack .../11-libcc1-0_12.1.0-2ubuntu1~22.04_arm64.deb ...
Unpacking libcc1-0:arm64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libitm1:arm64.
Preparing to unpack .../12-libitm1_12.1.0-2ubuntu1~22.04_arm64.deb ...
Unpacking libitm1:arm64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libasan6:arm64.
Preparing to unpack .../13-libasan6_11.3.0-1ubuntu1~22.04_arm64.deb ...
Unpacking libasan6:arm64 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package liblsan0:arm64.
Preparing to unpack .../14-liblsan0_12.1.0-2ubuntu1~22.04_arm64.deb ...
Unpacking liblsan0:arm64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libtsan0:arm64.
Preparing to unpack .../15-libtsan0_11.3.0-1ubuntu1~22.04_arm64.deb ...
Unpacking libtsan0:arm64 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package libubsan1:arm64.
Preparing to unpack .../16-libubsan1_12.1.0-2ubuntu1~22.04_arm64.deb ...
Unpacking libubsan1:arm64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libhwasan0:arm64.
Preparing to unpack .../17-libhwasan0_12.1.0-2ubuntu1~22.04_arm64.deb ...
Unpacking libhwasan0:arm64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libgcc-11-dev:arm64.
Preparing to unpack .../18-libgcc-11-dev_11.3.0-1ubuntu1~22.04_arm64.deb ...
Unpacking libgcc-11-dev:arm64 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package gcc-11.
Preparing to unpack .../19-gcc-11_11.3.0-1ubuntu1~22.04_arm64.deb ...
Unpacking gcc-11 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package gcc.
Preparing to unpack .../20-gcc_4%3a11.2.0-1ubuntu1_arm64.deb ...
Unpacking gcc (4:11.2.0-1ubuntu1) ...
Selecting previously unselected package libstdc++-11-dev:arm64.
Preparing to unpack .../21-libstdc++-11-dev_11.3.0-1ubuntu1~22.04_arm64.deb ...
Unpacking libstdc++-11-dev:arm64 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package g++-11.
Preparing to unpack .../22-g++-11_11.3.0-1ubuntu1~22.04_arm64.deb ...
Unpacking g++-11 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package g++.
Preparing to unpack .../23-g++_4%3a11.2.0-1ubuntu1_arm64.deb ...
Unpacking g++ (4:11.2.0-1ubuntu1) ...
Selecting previously unselected package make.
Preparing to unpack .../24-make_4.3-4.1build1_arm64.deb ...
Unpacking make (4.3-4.1build1) ...
Selecting previously unselected package patch.
Preparing to unpack .../25-patch_2.7.6-7build2_arm64.deb ...
Unpacking patch (2.7.6-7build2) ...
Selecting previously unselected package lto-disabled-list.
Preparing to unpack .../26-lto-disabled-list_24_all.deb ...
Unpacking lto-disabled-list (24) ...
Selecting previously unselected package dpkg-dev.
Preparing to unpack .../27-dpkg-dev_1.21.1ubuntu2.1_all.deb ...
Unpacking dpkg-dev (1.21.1ubuntu2.1) ...
Selecting previously unselected package build-essential.
Preparing to unpack .../28-build-essential_12.9ubuntu3_arm64.deb ...
Unpacking build-essential (12.9ubuntu3) ...
Selecting previously unselected package libfakeroot:arm64.
Preparing to unpack .../29-libfakeroot_1.28-1ubuntu1_arm64.deb ...
Unpacking libfakeroot:arm64 (1.28-1ubuntu1) ...
Selecting previously unselected package fakeroot.
Preparing to unpack .../30-fakeroot_1.28-1ubuntu1_arm64.deb ...
Unpacking fakeroot (1.28-1ubuntu1) ...
Selecting previously unselected package javascript-common.
Preparing to unpack .../31-javascript-common_11+nmu1_all.deb ...
Unpacking javascript-common (11+nmu1) ...
Selecting previously unselected package libalgorithm-diff-perl.
Preparing to unpack .../32-libalgorithm-diff-perl_1.201-1_all.deb ...
Unpacking libalgorithm-diff-perl (1.201-1) ...
Selecting previously unselected package libalgorithm-diff-xs-perl.
Preparing to unpack .../33-libalgorithm-diff-xs-perl_0.04-6build3_arm64.deb ...
Unpacking libalgorithm-diff-xs-perl (0.04-6build3) ...
Selecting previously unselected package libalgorithm-merge-perl.
Preparing to unpack .../34-libalgorithm-merge-perl_0.08-3_all.deb ...
Unpacking libalgorithm-merge-perl (0.08-3) ...
Selecting previously unselected package libexpat1-dev:arm64.
Preparing to unpack .../35-libexpat1-dev_2.4.7-1ubuntu0.2_arm64.deb ...
Unpacking libexpat1-dev:arm64 (2.4.7-1ubuntu0.2) ...
Selecting previously unselected package libjs-jquery.
Preparing to unpack .../36-libjs-jquery_3.6.0+dfsg+~3.5.13-1_all.deb ...
Unpacking libjs-jquery (3.6.0+dfsg+~3.5.13-1) ...
Selecting previously unselected package libjs-underscore.
Preparing to unpack .../37-libjs-underscore_1.13.2~dfsg-2_all.deb ...
Unpacking libjs-underscore (1.13.2~dfsg-2) ...
Selecting previously unselected package libjs-sphinxdoc.
Preparing to unpack .../38-libjs-sphinxdoc_4.3.2-1_all.deb ...
Unpacking libjs-sphinxdoc (4.3.2-1) ...
Selecting previously unselected package libpython3.10-dev:arm64.
Preparing to unpack .../39-libpython3.10-dev_3.10.6-1~22.04.2ubuntu1_arm64.deb ...
Unpacking libpython3.10-dev:arm64 (3.10.6-1~22.04.2ubuntu1) ...
Selecting previously unselected package libpython3-dev:arm64.
Preparing to unpack .../40-libpython3-dev_3.10.6-1~22.04_arm64.deb ...
Unpacking libpython3-dev:arm64 (3.10.6-1~22.04) ...
Selecting previously unselected package python3.10-dev.
Preparing to unpack .../41-python3.10-dev_3.10.6-1~22.04.2ubuntu1_arm64.deb ...
Unpacking python3.10-dev (3.10.6-1~22.04.2ubuntu1) ...
Selecting previously unselected package python3-dev.
Preparing to unpack .../42-python3-dev_3.10.6-1~22.04_arm64.deb ...
Unpacking python3-dev (3.10.6-1~22.04) ...
Selecting previously unselected package python3-setuptools.
Preparing to unpack .../43-python3-setuptools_59.6.0-1.2ubuntu0.22.04.1_all.deb ...
Unpacking python3-setuptools (59.6.0-1.2ubuntu0.22.04.1) ...
Selecting previously unselected package python3-wheel.
Preparing to unpack .../44-python3-wheel_0.37.1-2ubuntu0.22.04.1_all.deb ...
Unpacking python3-wheel (0.37.1-2ubuntu0.22.04.1) ...
Selecting previously unselected package python3-pip.
Preparing to unpack .../45-python3-pip_22.0.2+dfsg-1ubuntu0.2_all.deb ...
Unpacking python3-pip (22.0.2+dfsg-1ubuntu0.2) ...
Setting up javascript-common (11+nmu1) ...
Setting up lto-disabled-list (24) ...
Setting up python3-setuptools (59.6.0-1.2ubuntu0.22.04.1) ...
Setting up libalgorithm-diff-perl (1.201-1) ...
Setting up binutils-common:arm64 (2.38-4ubuntu2.1) ...
Setting up libctf-nobfd0:arm64 (2.38-4ubuntu2.1) ...
Setting up python3-wheel (0.37.1-2ubuntu0.22.04.1) ...
Setting up libfakeroot:arm64 (1.28-1ubuntu1) ...
Setting up libasan6:arm64 (11.3.0-1ubuntu1~22.04) ...
Setting up fakeroot (1.28-1ubuntu1) ...
update-alternatives: using /usr/bin/fakeroot-sysv to provide /usr/bin/fakeroot (fakeroot) in auto mode
update-alternatives: warning: skip creation of /usr/share/man/man1/fakeroot.1.gz because associated file /usr/share/man/man1/fakeroot-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/man1/faked.1.gz because associated file /usr/share/man/man1/faked-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/es/man1/fakeroot.1.gz because associated file /usr/share/man/es/man1/fakeroot-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/es/man1/faked.1.gz because associated file /usr/share/man/es/man1/faked-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/fr/man1/fakeroot.1.gz because associated file /usr/share/man/fr/man1/fakeroot-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/fr/man1/faked.1.gz because associated file /usr/share/man/fr/man1/faked-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/sv/man1/fakeroot.1.gz because associated file /usr/share/man/sv/man1/fakeroot-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/sv/man1/faked.1.gz because associated file /usr/share/man/sv/man1/faked-sysv.1.gz (of link group fakeroot) doesn't exist
Setting up libexpat1-dev:arm64 (2.4.7-1ubuntu0.2) ...
Setting up make (4.3-4.1build1) ...
Setting up patch (2.7.6-7build2) ...
Setting up libpython3.10-minimal:arm64 (3.10.6-1~22.04.2ubuntu1) ...
Setting up python3-pip (22.0.2+dfsg-1ubuntu0.2) ...
Setting up libubsan1:arm64 (12.1.0-2ubuntu1~22.04) ...
Setting up libhwasan0:arm64 (12.1.0-2ubuntu1~22.04) ...
Setting up libjs-jquery (3.6.0+dfsg+~3.5.13-1) ...
Setting up libbinutils:arm64 (2.38-4ubuntu2.1) ...
Setting up libalgorithm-diff-xs-perl (0.04-6build3) ...
Setting up libcc1-0:arm64 (12.1.0-2ubuntu1~22.04) ...
Setting up liblsan0:arm64 (12.1.0-2ubuntu1~22.04) ...
Setting up libitm1:arm64 (12.1.0-2ubuntu1~22.04) ...
Setting up libjs-underscore (1.13.2~dfsg-2) ...
Setting up libalgorithm-merge-perl (0.08-3) ...
Setting up libtsan0:arm64 (11.3.0-1ubuntu1~22.04) ...
Setting up libctf0:arm64 (2.38-4ubuntu2.1) ...
Setting up binutils-aarch64-linux-gnu (2.38-4ubuntu2.1) ...
Setting up binutils (2.38-4ubuntu2.1) ...
Setting up python3.10-minimal (3.10.6-1~22.04.2ubuntu1) ...
Setting up dpkg-dev (1.21.1ubuntu2.1) ...
Setting up libpython3.10-stdlib:arm64 (3.10.6-1~22.04.2ubuntu1) ...
Setting up libjs-sphinxdoc (4.3.2-1) ...
Setting up libgcc-11-dev:arm64 (11.3.0-1ubuntu1~22.04) ...
Setting up gcc-11 (11.3.0-1ubuntu1~22.04) ...
Setting up libpython3.10:arm64 (3.10.6-1~22.04.2ubuntu1) ...
Setting up python3.10 (3.10.6-1~22.04.2ubuntu1) ...
Setting up gcc (4:11.2.0-1ubuntu1) ...
Setting up libpython3.10-dev:arm64 (3.10.6-1~22.04.2ubuntu1) ...
Setting up libstdc++-11-dev:arm64 (11.3.0-1ubuntu1~22.04) ...
Setting up python3.10-dev (3.10.6-1~22.04.2ubuntu1) ...
Setting up libpython3-dev:arm64 (3.10.6-1~22.04) ...
Setting up g++-11 (11.3.0-1ubuntu1~22.04) ...
Setting up python3-dev (3.10.6-1~22.04) ...
Setting up g++ (4:11.2.0-1ubuntu1) ...
update-alternatives: using /usr/bin/g++ to provide /usr/bin/c++ (c++) in auto mode
update-alternatives: warning: skip creation of /usr/share/man/man1/c++.1.gz because associated file /usr/share/man/man1/g++.1.gz (of link group c++) doesn't exist
Setting up build-essential (12.9ubuntu3) ...
Processing triggers for bamfdaemon (0.5.6+22.04.20220217-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for desktop-file-utils (0.26-1ubuntu3) ...
Processing triggers for doc-base (0.11.1) ...
Processing 27 changed doc-base files, 1 added doc-base file...
Error in `/usr/share/doc-base/libexpat1-dev.expat', line 9: all `Format' sections are invalid.
Error in `/usr/share/doc-base/printer-driver-pnm2ppa.pnm2ppa-calibrate', line 16: all `Format' sections are invalid.
Error in `/usr/share/doc-base/doc-base', line 13: all `Format' sections are invalid.
Error in `/usr/share/doc-base/libffi-dev.libffi', line 18: all `Format' sections are invalid.
Error in `/usr/share/doc-base/libcrack2.libcrack2', line 13: all `Format' sections are invalid.
Error in `/usr/share/doc-base/fonts-sil-padauk.fonts-sil-padauk-features', line 9: all `Format' sections are invalid.
Error in `/usr/share/doc-base/libxml-parser-perl.libxml-parser-perl', line 10: all `Format' sections are invalid.
Error in `/usr/share/doc-base/fonts-sil-abyssinica.fonts-sil-abyssinica-features', line 9: all `Format' sections are invalid.
Error in `/usr/share/doc-base/cracklib-runtime.cracklib-runtime', line 11: all `Format' sections are invalid.
Error in `/usr/share/doc-base/xterm.xterm-faq', line 14: all `Format' sections are invalid.
Error in `/usr/share/doc-base/kbd.kbd-font-formats', line 10: all `Format' sections are invalid.
Error in `/usr/share/doc-base/libdvbv5-reference', line 9: all `Format' sections are invalid.
Error in `/usr/share/doc-base/shared-mime-info.shared-mime-info', line 12: all `Format' sections are invalid.
Error in `/usr/share/doc-base/libpng16-16.libpng16', line 25: all `Format' sections are invalid.
Error in `/usr/share/doc-base/install-docs-man', line 11: all `Format' sections are invalid.
Error in `/usr/share/doc-base/printer-driver-pnm2ppa.pnm2ppa-color', line 17: all `Format' sections are invalid.
Error in `/usr/share/doc-base/xterm.xterm-ctlseqs', line 9: all `Format' sections are invalid.
Error in `/usr/share/doc-base/man-db.man-db', line 12: all `Format' sections are invalid.
Error in `/usr/share/doc-base/printer-driver-foo2zjs-common.foo2zjs', line 11: all `Format' sections are invalid.
Error in `/usr/share/doc-base/gdisk.gdisk', line 9: all `Format' sections are invalid.
Error in `/usr/share/doc-base/dc.dc', line 14: all `Format' sections are invalid.
Error in `/usr/share/doc-base/printer-driver-pnm2ppa.pnm2ppa-ppa-networking', line 20: all `Format' sections are invalid.
Error in `/usr/share/doc-base/bc.bc', line 17: all `Format' sections are invalid.
Error in `/usr/share/doc-base/base-passwd.users-and-groups', line 13: all `Format' sections are invalid.
Error in `/usr/share/doc-base/ocl-icd-libopencl1', line 11: all `Format' sections are invalid.
Error in `/usr/share/doc-base/fontconfig.fontconfig-user', line 17: all `Format' sections are invalid.
Note: `install-docs --verbose --check file_name' may give more details about the above errors.
Processing triggers for gnome-menus (3.36.0-1ubuntu3) ...
Processing triggers for libc-bin (2.35-0ubuntu3.1) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
cat@lubancat:~$ pip3 -V
pip 22.0.2 from /usr/lib/python3/dist-packages/pip (python 3.10)
到这里已经安装好了pip 22.0.2
用pip查看已经安装好的python模块:
cat@lubancat:~$ pip list
Package Version
blinker 1.4
Brotli 1.0.9
certifi 2020.6.20
chardet 4.0.0
click 8.0.3
colorama 0.4.4
cryptography 3.4.8
cupshelpers 1.0
dbus-python 1.2.18
defer 1.0.6
distro 1.7.0
distro-info 1.1build1
httplib2 0.20.2
idna 3.3
importlib-metadata 4.6.4
jeepney 0.7.1
keyring 23.5.0
language-selector 0.1
launchpadlib 1.10.16
lazr.restfulclient 0.14.4
lazr.uri 1.0.6
macaroonbakery 1.3.1
more-itertools 8.10.0
mutagen 1.45.1
netifaces 0.11.0
oauthlib 3.2.0
olefile 0.46
onboard 1.4.1
pexpect 4.8.0
Pillow 9.0.1
pip 22.0.2
protobuf 3.12.4
ptyprocess 0.7.0
pycairo 1.20.1
pycryptodomex 3.11.0
pycups 2.0.1
PyGObject 3.42.1
PyJWT 2.3.0
pymacaroons 0.13.0
PyNaCl 1.5.0
pyparsing 2.4.7
pyRFC3339 1.1
python-apt 2.4.0+ubuntu1
python-dateutil 2.8.1
pytz 2022.1
pyxattr 0.7.2
pyxdg 0.27
PyYAML 5.4.1
reportlab 3.6.8
requests 2.25.1
SecretStorage 3.3.1
setuptools 59.6.0
six 1.16.0
ssh-import-id 5.11
systemd-python 234
ubuntu-advantage-tools 8001
ubuntu-drivers-common 0.0.0
unattended-upgrades 0.1
urllib3 1.26.5
wadllib 1.3.6
websockets 9.1
wheel 0.37.1
xdg 5
xkit 0.0.0
yt-dlp 2022.4.8
zipp 1.0.0
发现已经安装了相当多的常用模块。接下来就可以愉快的开始自己的编程开发了。。。
