我已经使用来自 https://github.com/nxp的基于 kirkstone 5.15.52-2.1.0 BSP 的$ bitbake imx-image-full构建了一个新图像。
在成功构建和部署“完整”图像后,我尝试使用 Gstermer 使用 mipi csi 捕获图片。 通过使用以下命令 $ gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=1 ! 视频/x-raw,宽度=640,高度=480!jpegenc!文件接收器位置=/tmp/pic_one.jpg 我收到以下错误: 剧透 (Highlight to read)Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error. ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src1: Internal data stream error. Additional debug info: ../git/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: streaming stopped, reason not-negotiated (-4) Additional debug info: ../git/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src1: streaming stopped, reason not-negotiated (-4) ERROR: pipeline doesn't want to preroll. ERROR: pipeline doesn't want to preroll. Execution ended after 0:00:00.000408375 Setting pipeline to NULL ... Freeing pipeline ... Setting pipeline to PAUSED ...Pipeline is live and does not need PREROLL ...Pipeline is PREROLLED ...Setting pipeline to PLAYING ...ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src1: Internal data stream error.Additional debug info:../git/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:streaming stopped, reason not-negotiated (-4)Additional debug info:../git/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src1:streaming stopped, reason not-negotiated (-4)ERROR: pipeline doesn't want to preroll.ERROR: pipeline doesn't want to preroll.Execution ended after 0:00:00.000408375Setting pipeline to NULL ...Freeing pipeline ... 顺便说一句,当我尝试将上述命令与来自 NXP 网站的 NXP prebuild 可下载图像一起使用时,该命令运行良好...... 您能否就可能出现的问题提出建议,我还发现缺少一些工具,例如“lsusb”和“ping”? |
1935个成员聚集在这个小组
36428 浏览 0 评论
4971 浏览 1 评论
6114 浏览 1 评论
6821 浏览 0 评论
4252 浏览 0 评论
653浏览 2评论
646浏览 2评论
647浏览 2评论
737浏览 2评论
849浏览 2评论
GMT+8, 2024-12-27 01:15 , Processed in 1.081369 second(s), Total 77, Slave 59 queries .
