使用 RT1176 进行 SPI 通信,我们确实看到了奇怪的时钟行为:每 8 个时钟信号都非常短。我在下面附上了两张图片,显示每个时钟都会发生这种情况,放大版本显示时钟信号有多短。值得注意的是,数据正确地跟随时钟,所以第 8 位的信号也被缩短了. 在测量中,时钟显示为黄色,SDO 显示为蓝色。
请注意,该线路上的噪声与我们进行测量的位置有关。与 RT1176 的 SPI 通信的其他实例显示相同的行为,即使信号噪声较小。 三字节 SPI 传输。时钟:黄色,SDO:蓝色。用红色箭头标记的缩短信号 放大一个字节传输。第 8 个缩短的时钟标有红色箭头。时钟:黄色。SDO:蓝色 RT1176 SPI 接口设置为主机,参数如下: { uint32_t clock_freq; lpspi_master_config_t sdk_spi_config; edma_config_t sdk_dma_config; uint8_t dma_mux_channel_rx, dma_mux_channel_tx; LPSPI_Type* instance; //Init SPI LPSPI_MasterGetDefaultConfig(&sdk_spi_config); instance = LPSPI5; clock_freq = CLOCK_GetRootClockFreq(kCLOCK_Root_Lpspi5); sdk_spi_config.baudRate = 1000000/2; sdk_spi_config.bitsPerFrame = 8; sdk_spi_config.cpha = kLPSPI_ClockPhaseFirstEdge; sdk_spi_config.cpol = kLPSPI_ClockPolarityActiveLow; sdk_spi_config.direction = kLPSPI_MsbFirst; sdk_spi_config.pcsToSckDelayInNanoSec = 100; sdk_spi_config.lastSckToPcsDelayInNanoSec = 100; sdk_spi_config.betweenTransferDelayInNanoSec = 10; sdk_spi_config.whichPcs = kLPSPI_Pcs0; sdk_spi_config.pcsActiveHighOrLow = kLPSPI_PcsActiveLow; sdk_spi_config.pinCfg = kLPSPI_SdiInSdoOut; sdk_spi_config.dataOutConfig = kLpspiDataOutTristate; instance->CR |= LPSPI_CR_DBGEN_MASK; //enable LPSPI in debug mode LPSPI_MasterInit(instance, &sdk_spi_config, clock_freq); //Data transfer uint8_t buf_tx[9] = {0}; uint8_t buf_rx[9] = {0}; lpspi_transfer_t transfer; txBuffer[0] = 0x24 | (1 << 7); transfer.txData = buf_tx; transfer.rxData = buf_rx; transfer.dataSize = 9; transfer.configFlags = kLPSPI_MasterPcs0 | kLPSPI_MasterPcsContinuous; if((retval = LPSPI_MasterTransferBlocking(instance, &transfer)) != kStatus_Success) { printf("Transfer failed! "); if(retval == kStatus_LPSPI_Busy) printf("kStatus_LPSPI_Busy "); if(retval == kStatus_InvalidArgument) printf("kStatus_InvalidArgument "); if(retval == kStatus_LPSPI_Timeout) printf("kStatus_LPSPI_Timeout "); return false; } return true; } 传输成功,kStatusSuccess由LPSPI_MasterTransferBlocking()返回。我们正在使用最新的 SDK。 |
1975个成员聚集在这个小组
36593 浏览 0 评论
6040 浏览 1 评论
6264 浏览 1 评论
6951 浏览 0 评论
4331 浏览 0 评论
742浏览 2评论
721浏览 2评论
733浏览 2评论
810浏览 2评论
928浏览 2评论
GMT+8, 2025-3-6 12:49 , Processed in 1.032789 second(s), Total 43, Slave 37 queries .
