大家好
我们在我们的一款产品中使用 i.MX28,它使用以下寄存器设置在 180MHz EMI_CLK 上工作—— volatile unsigned int * DRAM_REG = (volatile unsigned int*) HW_DRAM_CTL00_ADDR; DRAM_REG[0] = 0x00000000; DRAM_REG[1] = 0x00000000; DRAM_REG[2] = 0x00000000; DRAM_REG[3] = 0x00000000; DRAM_REG[4] = 0x00000000; DRAM_REG[5] = 0x00000000; DRAM_REG[6] = 0x00000000; DRAM_REG[7] = 0x00000000; DRAM_REG[8] = 0x00000000; DRAM_REG[9] = 0x00000000; DRAM_REG[10] = 0x00000000; DRAM_REG[11] = 0x00000000; DRAM_REG[12] = 0x00000000; DRAM_REG[13] = 0x00000000; DRAM_REG[14] = 0x00000000; DRAM_REG[15] = 0x00000000; DRAM_REG[16] = 0x00000000; DRAM_REG[17] = 0x00000100; DRAM_REG[18] = 0x00000000; DRAM_REG[19] = 0x00000000; DRAM_REG[20] = 0x00000000; DRAM_REG[21] = 0x00000000; DRAM_REG[22] = 0x00000000; DRAM_REG[23] = 0x00000000; DRAM_REG[24] = 0x00000000; DRAM_REG[25] = 0x00000000; DRAM_REG[26] = 0x00010101; DRAM_REG[27] = 0x01010101; DRAM_REG[28] = 0x000f0f01; DRAM_REG[29] = 0x0f02020a; DRAM_REG[30] = 0x00000000; DRAM_REG[31] = 0x00000101;//64 MB RAM with 4 banks instaed of 8 banks DRAM_REG[32] = 0x00000100; DRAM_REG[33] = 0x00000100; DRAM_REG[34] = 0x00000000; DRAM_REG[35] = 0x00000002; DRAM_REG[36] = 0x01010000; DRAM_REG[37] = 0x07080403; DRAM_REG[38] = 0x06005003; DRAM_REG[39] = 0x0a0000c8; DRAM_REG[40] = 0x0200A06C; DRAM_REG[41] = 0x0002030c; DRAM_REG[42] = 0x0036a609; DRAM_REG[43] = 0x031a0612; DRAM_REG[44] = 0x02030202; DRAM_REG[45] = 0x00c8001c; DRAM_REG[46] = 0x00000000; DRAM_REG[47] = 0x00000000; DRAM_REG[48] = 0x00012100; DRAM_REG[49] = 0xffff0303; DRAM_REG[50] = 0x00012100; DRAM_REG[51] = 0xffff0303; DRAM_REG[52] = 0x00012100; DRAM_REG[53] = 0xffff0303; DRAM_REG[54] = 0x00012100; DRAM_REG[55] = 0xffff0303; DRAM_REG[56] = 0x00000003; DRAM_REG[57] = 0x00000000; DRAM_REG[58] = 0x00000000; DRAM_REG[59] = 0x00000000; DRAM_REG[60] = 0x00000000; DRAM_REG[61] = 0x00000000; DRAM_REG[62] = 0x00000000; DRAM_REG[63] = 0x00000000; DRAM_REG[64] = 0x00000000; DRAM_REG[65] = 0x00000000; DRAM_REG[66] = 0x00000612; DRAM_REG[67] = 0x01000f02; DRAM_REG[68] = 0x06120612; DRAM_REG[69] = 0x00000200; DRAM_REG[70] = 0x00020007; DRAM_REG[71] = 0xf4004a27; DRAM_REG[72] = 0xf4004a27; DRAM_REG[73] = 0xf4004a27; DRAM_REG[74] = 0xf4004a27; DRAM_REG[75] = 0x07000300; DRAM_REG[76] = 0x07000300; DRAM_REG[77] = 0x07400300; DRAM_REG[78] = 0x07400300; DRAM_REG[79] = 0x00000005; DRAM_REG[80] = 0x00000000; DRAM_REG[81] = 0x00000000; DRAM_REG[82] = 0x00000000; DRAM_REG[83] = 0x00000000; DRAM_REG[84] = 0x08040201; DRAM_REG[85] = 0x000f1133; DRAM_REG[86] = 0x00000000; DRAM_REG[87] = 0x00001f04; DRAM_REG[88] = 0x00001f04; DRAM_REG[89] = 0x00001f04; DRAM_REG[90] = 0x00001f04; DRAM_REG[91] = 0x00001f04; DRAM_REG[92] = 0x00001f04; DRAM_REG[93] = 0x00001f04; DRAM_REG[94] = 0x00001f04; DRAM_REG[95] = 0x00000000; DRAM_REG[96] = 0x00000000; DRAM_REG[97] = 0x00000000; DRAM_REG[98] = 0x00000000; DRAM_REG[99] = 0x00000000; DRAM_REG[100] = 0x00000000; DRAM_REG[101] = 0x00000000; DRAM_REG[102] = 0x00000000; DRAM_REG[103] = 0x00000000; DRAM_REG[104] = 0x00000000; DRAM_REG[105] = 0x00000000; DRAM_REG[106] = 0x00000000; DRAM_REG[107] = 0x00000000; DRAM_REG[108] = 0x00000000; DRAM_REG[109] = 0x00000000; DRAM_REG[110] = 0x00000000; DRAM_REG[111] = 0x00000000; DRAM_REG[112] = 0x00000000; DRAM_REG[113] = 0x00000000; DRAM_REG[114] = 0x00000000; DRAM_REG[115] = 0x00000000; DRAM_REG[116] = 0x00000000; DRAM_REG[117] = 0x00000000; DRAM_REG[118] = 0x00000000; DRAM_REG[119] = 0x00000000; DRAM_REG[120] = 0x00000000; DRAM_REG[121] = 0x00000000; DRAM_REG[122] = 0x00000000; DRAM_REG[123] = 0x00000000; DRAM_REG[124] = 0x00000000; DRAM_REG[125] = 0x00000000; DRAM_REG[126] = 0x00000000; DRAM_REG[127] = 0x00000000; DRAM_REG[128] = 0x00000000; DRAM_REG[129] = 0x00000000; DRAM_REG[130] = 0x00000000; DRAM_REG[131] = 0x00000000; DRAM_REG[132] = 0x00000000; DRAM_REG[133] = 0x00000000; DRAM_REG[134] = 0x00000000; DRAM_REG[135] = 0x00000000; DRAM_REG[136] = 0x00000000; DRAM_REG[137] = 0x00000000; DRAM_REG[138] = 0x00000000; DRAM_REG[139] = 0x00000000; DRAM_REG[140] = 0x00000000; DRAM_REG[141] = 0x00000000; DRAM_REG[142] = 0x00000000; DRAM_REG[143] = 0x00000000; DRAM_REG[144] = 0x00000000; DRAM_REG[145] = 0x00000000; DRAM_REG[146] = 0x00000000; DRAM_REG[147] = 0x00000000; DRAM_REG[148] = 0x00000000; DRAM_REG[149] = 0x00000000; DRAM_REG[150] = 0x00000000; DRAM_REG[151] = 0x00000000; DRAM_REG[152] = 0x00000000; DRAM_REG[153] = 0x00000000; DRAM_REG[154] = 0x00000000; DRAM_REG[155] = 0x00000000; DRAM_REG[156] = 0x00000000; DRAM_REG[157] = 0x00000000; DRAM_REG[158] = 0x00000000; DRAM_REG[159] = 0x00000000; DRAM_REG[160] = 0x00000000; DRAM_REG[161] = 0x00000000; DRAM_REG[162] = 0x00010000; DRAM_REG[163] = 0x00030404; DRAM_REG[164] = 0x00000003; DRAM_REG[165] = 0x00000000; DRAM_REG[166] = 0x00000000; DRAM_REG[167] = 0x00000000; DRAM_REG[168] = 0x00000000; DRAM_REG[169] = 0x00000000; DRAM_REG[170] = 0x00000000; DRAM_REG[171] = 0x01010000; DRAM_REG[172] = 0x01000000; DRAM_REG[173] = 0x03030000; DRAM_REG[174] = 0x00010303; DRAM_REG[175] = 0x01020202; DRAM_REG[176] = 0x00000000; DRAM_REG[177] = 0x02040303; DRAM_REG[178] = 0x21002103; DRAM_REG[179] = 0x00061200; DRAM_REG[180] = 0x06120612; DRAM_REG[181] = 0x06420642; DRAM_REG[182] = 0x04420442; DRAM_REG[183] = 0x20042004; DRAM_REG[184] = 0x20042004; DRAM_REG[185] = 0x80008000; DRAM_REG[186] = 0x80008000; DRAM_REG[187] = 0xC000C000; DRAM_REG[188] = 0xC000C000; DRAM_REG[189] = 0xffffffff; ---------------------------------------------- ---------------------------------------------- ------------------------------ 另一个 reg FRAC0 设置在这里 div =24 //180MHz HW_CLKCTRL_FRAC0_SET(0x00008000); HW_CLKCTRL_FRAC0_SET(0x00003F00); div = (~div); HW_CLKCTRL_FRAC0_CLR(BF_CLKCTRL_FRAC0_EMIFRAC(div)); HW_CLKCTRL_FRAC0_CLR(0x00008000); 我们想把时钟从180MHz改成90MHz,所以想知道代码中哪里需要改动?这些电阻器设置都在 uboot 和 BSP 中,我们正在两个地方更新。我们尝试通过更改一些寄存器设置并观察到时钟已更改但应用程序未启动。 |
1965个成员聚集在这个小组
36573 浏览 0 评论
5979 浏览 1 评论
6247 浏览 1 评论
6939 浏览 0 评论
4326 浏览 0 评论
738浏览 2评论
709浏览 2评论
727浏览 2评论
802浏览 2评论
924浏览 2评论
GMT+8, 2025-2-24 23:48 , Processed in 1.257344 second(s), Total 74, Slave 58 queries .
