SL9486A 100V Input, 3.5A, Switching Current Limit Step-Down Converter DESCRIPtiON The SL9486A is a high-voltage, step-down, switching regulator that delivers up to 2A of continuous current to the load. It integrates a high-side, high-voltage, power MOSFET with a current limit of 3.5A, typically. The wide 5V to 100V input range accommodates a variety of step-down applications, making it ideal for automotive, industry, and lighting applications. Hysteretic voltage-mode control is employed for very fast response. The switching frequency can be up to 1MHz, allowing for small component size. Thermal shutdown and short-circuit protection (SCP) provide reliable and fault-tolerant operations. A 200μA quiescent current allows the SL9486A to be used in battery-powered applications. The SL9486A is available in ESOP8 package. FEATURES ・Wide 5V to 100V Input Range ・3.5A Typical Peak Switching Current Limit ・Hysteretic Control: No Compensation ・Up to 1MHz Switching Frequency ・PWM Dimming Control Input for LED Application ・Short-Circuit Protection (SCP) with Integrated High-Side MOSFET ・200μA Quiescent Current ・Thermal Shutdown ・Packages: Pb-free Packages, ESOP8 APPLICATIONS ・Scooters, E-Bike Control Power Supplies ・Solar Energy Systems ・Automotive System Power ・Industrial Power Supplies ・High-Power LED Drivers TYPICAL APPLICATION ![]() |
2179 浏览 0 评论
5767 浏览 0 评论
3352 浏览 2 评论
6362 浏览 2 评论
4182 浏览 0 评论
GMT+8, 2024-12-25 21:25 , Processed in 0.714702 second(s), Total 56, Slave 42 queries .
