我在 S32GRDB2 上测试 sja1110 ,我将 SW12 设置为 1-1,启动 S32GRDB2 时 sja1110 正常,日志如下:
[3.577120] sja1110 spi5.0:探测 uc [3.577321] sja1110 spi5.1:探测开关 [3.577744] sja1110 spi5.1:无法从设备树中获取 GPIO [3.577769] sja1110 spi5.1:[sja1110_up_post_work_probe] 尝试初始化 switcherprobe [3.578382] sja1110 spi5.1: [sja1110_init_hw] loaded fw 'sja1110_switch.bin' [3.578483] sja1110 spi5.1: [sja1110_pre_switch_upload] 找到大小为 2276 [3.578656] sja1110 的开关配置 [3.578656] sja1110 : 上传 config1.7 ... ] sja1110 spi5.1:配置成功! [ 3.614856] sja1110 spi5.0: [sja1110_post_probe_upload_worker] 试图初始化 uC [ 3.616505] EXT4-fs (mmcblk0p2): 重新安装。Opts: (null) [ 3.620682] sja1110 spi5.0: [sja1110_init_hw] loaded fw 'sja1110_uc.bin' [ 3.620702] sja1110 spi5.0: [sja1110_pre_uc_upload] 找到大小为 320312 的固件 [ 3.620812] sja1110 spi5.0: [sja1110_pre_uc_upload] 固件似乎有效 [ 3.620870] sja1110 spi5.0: µpreucat spi5.0 未准备好下载 [sja11] =0x31) [ 3.621112] sja1110 spi5.0: 上传固件... 然后我做了如下cmd: rmmod sja1110 modprobe sja1110 然后一些错误消息打印如下: root@s32g274ardb2:〜#rmmod sja1110 [365.287514] sja1110 spi5.1:[sja1110_remove] [365.288179] sja1110 spi5.0:[sja1110_remove] root@s32g274 root@s32g274 rootb2 :s32g274 root 〜asot 〜asot 〜asot.and: 〜soct: 0: 探测 uc [367.669021] sja1110 spi5.1: 探测开关 [367.669437] sja1110 spi5.1: 无法从设备树 [367.669460] sja1110 spi5.1: [sja1110_post_probe_upload_worker] 尝试初始化开关 [ 95917.6] 1: [sja1110_init_hw] 加载 fw 'sja1110_switch.bin' [367.669701] sja1110 spi5.1: [sja1110_pre_switch_upload] 找到大小为 2276 [367.669857] sja1110 spi5.1: 上传配置的开关配置... [367.698018]sja1110 spi5.1:配置成功! [ 367.698064] sja1110 spi5.0: [sja1110_post_probe_upload_worker] Trying to initialize uC [ 367.698711] sja1110 spi5.0: [sja1110_init_hw] loaded fw 'sja1110_uc.bin' r[ 367.698728] sja1110 spi5.0: [sja1110_pre_uc_upload] Found firmware of size 320312 o[ 367.698833] sja1110 spi5.0: [sja1110_pre_uc_upload] firmware appears to be valid o[ 367.698890] sja1110 spi5.0: [sja1110_uc_parse_status] Invalid status header (0x5b) t[ 367.698899] sja1110 spi5.0: [sja1110_uc_read_status] Parsing uC status失败 -22 @[ 367.698905] sja1110 spi5.0: [sja1110_pre_uc_upload] 无法读取 µC 状态 s[ 367.698957] sja1110 spi5.0: [sja1110_uc_parse_status] 无效状态标头 (0x5b) 3 [367.698964] SJA1110 SPI5.0:[SJA11110_UC_READ_STATUS] -22 2 [367.698972] SJA1110 SPI5.0:[SJA1110_PRE_UC_UPLOAD]无法读取 G [367.698972] SJA1110 SPI5.0: header (0x5b) 2[ 367.699030] sja1110 spi5.0: [sja1110_uc_read_status] 解析 uC 状态失败,-22 7[ 367.699036] sja1110 spi5.0: [sja1110_pre_uc_upload] 无法读取 µC 状态 4[ 367.6990861] [367.699036] sja1110_uc_parse_status] 无效状态标头 (0x5b) a[ 367.699093] sja1110 spi5.0: [sja1110_uc_read_status] 解析 uC 状态失败,-22 r[ 367.699099] sja1110 spi5.0: [sja1110_pre_uc_upload status] 无法读取 µC 状态 D [367.699150] SJA1110 SPI5.0:[SJA11110_UC_PARSE_STATUS]无效状态标题(0x5b)b [ 367.699157] SJA1110 SPI5.0 :未读取 µC 状态 :[ 367.699214] sja1110 spi5.0: [sja1110_uc_parse_status] 无效状态标头 (0x5b) ~[ 367.699221] sja1110 spi5.0: [sja1110_uc_read_status] 解析 uC 状态失败,-22 #[ 367.15: sjapi] 69922 [sja1110_pre_uc_upload] 无法读取 µC 状态 [367.699277] sja1110 spi5.0: [sja1110_uc_parse_status] 无效状态标头 (0x5b) [367.699284] sja1110 spi5.0: [sja1110_uc_read_status] 解析 uC 状态失败,-222 [367.699290] SJA1111S SPI5.0:[SJA11110_PRE_UC_UPLOAD]无法读取µC状态 [367.699340] SJA11110 SPI5.0:[SJA1110_UC_PARESE_STATUS] fifter fift fift fifte 22 [ 367.699354] sja1110 spi5.0: [sja1110_pre_uc_upload] Could not read µC status [ 367.699404] sja1110 spi5.0: [sja1110_uc_parse_status] Invalid status header (0x5b) [ 367.699411] sja1110 spi5.0: [sja1110_uc_read_status] Parsing uC status failed with -22 [367.699417] sja1110 spi5.0: [sja1110_pre_uc_upload] 无法读取 µC 状态 [367.699467] sja1110 spi5.0: [sja1110_uc_parse_status] 无效状态标头 (0x5b) [ 367.699474] sja1110 spi5.0: [sja1110_uc_read_status] 解析 uC 状态失败,-22 [ 367.699480] sja1110 spi5.0: [sja1110_pre_uc_upload] 无法读取 µC 状态 [ 367.699487] sja1110: spi5.022 检查固件失败 |
1963个成员聚集在这个小组
36571 浏览 0 评论
5974 浏览 1 评论
6244 浏览 1 评论
6937 浏览 0 评论
4325 浏览 0 评论
738浏览 2评论
709浏览 2评论
727浏览 2评论
802浏览 2评论
924浏览 2评论
GMT+8, 2025-2-23 18:33 , Processed in 0.944686 second(s), Total 40, Slave 35 queries .
