1 个讨论
能。把它写入开机启动项就好了。
import RPi.GPIO as GPIO import time import os,sys import signal GPIO.setmode(GPIO.BCM) #define GPIO pin pin_btn=7 pin_led=17 GPIO.setup(pin_btn, GPIO.IN, pull_up_down=GPIO.PUD_UP) GPIO.setup(pin_led, GPIO.OUT, initial=GPIO.LOW) press_time=0 count_down=10 led_on=1 def cleanup(): '''释放资源,不然下次运行是可能会收到警告 ''' print('clean up') GPIO.cleanup() def handleSIGTERM(signum, frame): #cleanup() sys.exit()#raise an exception of type SystemExit def onPress(channel): global press_time,count_down print('pressed') press_time+=1 if press_time >3: press_time=1 if press_time==1: GPIO.output(pin_led, 1) print('system will restart in %s'%(count_down)) elif press_time==2: print('system will halt in %s'%(count_down)) elif press_time==3: GPIO.output(pin_led, 0) |
6352 浏览 0 评论
6190 浏览 0 评论
6978 浏览 0 评论
4488 浏览 2 评论
7153 浏览 2 评论
GMT+8, 2025-1-24 09:29 , Processed in 0.711723 second(s), Total 48, Slave 38 queries .
