我正在尝试为我的 imx6sx saber sdb 板刷新 imx-image-core。
CPU: i.MX6SX rev1.2 996 MHz (running at 792 MHz) CPU: Extended Commercial temperature grade (-20C to 105C) at 43C Reset cause: POR Model: NXP i.MX6 SoloX SDB RevB Board Board: MX6SX SABRE SDB revD DRAM: 1 GiB Core: 119 devices, 22 uclasses, devicetree: separate PMIC: PFUZE100! DEV_ID=0x11 REV_ID=0x21 MMC: FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 3 Loading Environment from MMC... *** Warning - bad CRC, using default environment -Video Link 0 (800 x 480) [0] lcdif@2220000, video In: serial Out: serial Err: serial SEC0: RNG instantiated switch to partitions #0, OK mmc3 is current device flash target is MMC:3 Net: eth0: ethernet@2188000 [PRIME]Get shared mii bus on ethernet@21b4000 , eth1: ethernet@21b4000 Fastboot: Normal Normal Boot Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc3 is current device Can't set block device Can't set block device Booting from net ... ethernet@2188000 Waiting for PHY auto negotiation to complete......................................... TIMEOUT ! Could not initialize PHY ethernet@2188000 BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again ethernet@2188000 Waiting for PHY auto negotiation to complete......................................... TIMEOUT ! Could not initialize PHY ethernet@2188000 BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 我该怎么办,似乎有什么问题?也许我的密码配置或我的 SD 卡没有正确闪烁? |
1865个成员聚集在这个小组
36179 浏览 0 评论
4282 浏览 0 评论
5912 浏览 1 评论
6655 浏览 0 评论
4105 浏览 0 评论
530浏览 2评论
520浏览 2评论
515浏览 2评论
596浏览 2评论
647浏览 2评论
GMT+8, 2024-9-20 12:11 , Processed in 1.496040 second(s), Total 76, Slave 60 queries .
