嗨,我正在启动我们自己的董事会。
U-boot 不稳定,每次都卡在不同的地方。 这是3个卡住的日志 1.卡在DRAM INFO U-Boot 2020.04-脏(2022 年 11 月 1 日 - 18:09:02 +0900) SoC:LS1046AE Rev1.0 (0x87070010) 时钟配置: CPU0(A72):1600 MHz CPU1(A72):1600 MHz CPU2(A72):1600 MHz CPU3(A72):1600 MHz 总线:600 MHz DDR:1600 MT/s FMAN: 900 MHz Reset Configuration Word (RCW): 00000000: 0c100010 12000000 00000000 00000000 00000010: 10405577 40a00016 40000000 c1000000 00000020: 00200000 00000000 00000000 0003affc 00000030: 20004504 04201101 00000096 00000001 Model: LS1046A FRWY Board Board: LS1046AFRWY, Rev: B, boot from QSPI SD1_CLK1 = 100.00MHZ,SD1_CLK2 = 100.00MHZ DRAM:7.9 GiB(DDR4,64 位,CL=11,ECC 关闭)2.坚持“同步中止”处理程序 U-Boot 2020.04-dirty (Nov 01 2022 - 18:09:02 +0900) SoC:LS1046AE Rev1.0 (0x87070010) 时钟配置: CPU0(A72):1600 MHz CPU1(A72):1600 MHz CPU2(A72): 1600 MHz CPU3(A72):1600 MHz Bus: 600 MHz DDR: 1600 MT/s FMAN: 900 MHz Reset Configuration Word (RCW): 00000000: 0c100010 12000000 00000000 00000000 00000010: 10405577 40a00016 40000000 c1000000 00000020: 00200000 00000000 00000000 0003affc 00000030: 20004504 04201101 00000096 00000001 型号:LS1046A FRWY 电路板电路板:LS1046AFRWY,修订版:B,从 QSPI SD1_CLK1 = 100.00MHZ,SD1_CLK2 = 100.00MHZ 启动DRAM:7.9 GiB(DDR4,SERDES CL11 关闭)使用协议 1 : 4160 (0x1040) 使用 SERDES2 协议:21879 (0x5577) NAND:fsl_ifc_chip_init:地址不匹配任何芯片选择 0 MiB MMC:FSL_SDHC:0 EEPROM:读取失败。 In: serial Out: serial Err: serial Net: Invalid SerDes protocol 0x1040 for LS1046AFRWY unrecognized JEDEC id bytes: ef, 60, 18 "Synchronous Abort" handler, esr 0x96000004 elr: 000000008204a6a4 lr : 000000008204a68c (reloc) elr: 00000000fbd786a4 lr : 00000000fbd7868c x0 : f2a12001d2808001 x1 : 0000000000001070 x2 : 00000000fbdc8000 x3 : 0000000000001071 x4 : 00000000fbc2b880 x5 : 00000000fbc2bd60 x6 : 00000000fbdc83f0 x7 : 00000000fbdc8400 x8 : 00000000fbc43ad0 x9 : 0000000000000008 x10: 0000000000000010 x11: 00000000fbc26f8c x12: 0000000000001238 x13: 0000000000001174 x14: 00000000fbc26fdc x15: 0000000000000002 x16: 0000000000000000 x17: 0000000000000000 x18: 00000000fbc29dc0 x19: 00000000fbc33ad0 x20: f2a12001d2808001 x21: 0000000001a00000 x22: 0000000000000000 x23: 0000000000000000 x24: 0000000000000000 x25: 0000000000000000 x26: 0000000000000000 x27:0000000000000000 x28:0000000000000000 x29:00000000fbc27200 代码:90000200 91089c00 9400b6f5 17ffffd7 (f940settingc400) 重置 CPU ... 重置3. 卡在案例 2 的同一个地方,但使用不同的同步处理程序。 这应该被视为 DDR 设置问题吗? |
1866个成员聚集在这个小组
36188 浏览 0 评论
4285 浏览 0 评论
5915 浏览 1 评论
6658 浏览 0 评论
4109 浏览 0 评论
535浏览 2评论
526浏览 2评论
519浏览 2评论
600浏览 2评论
651浏览 2评论
GMT+8, 2024-9-21 08:31 , Processed in 1.079776 second(s), Total 46, Slave 40 queries .
