扫一扫,分享给好友
此段SAMPLE程序代码只有看显示波器slaveAddress波型,但没有数据资料,请问需要修改哪里呢?谢谢~
/**************************************************** ********************************* * 定义 ****************** ****************************************************** **********/ #define EXAMPLE_MASTER I3C #define EXAMPLE_I2C_BAUDRATE 400000 #define I3C_MASTER_CLOCK_FREQUENCY CLOCK_Geti3cClkFreq() #define I3C_MASTER_SLAVE_ADDR_7BIT 0x1E #define WAIT_TIME 1000 #define I3C_DATA_LENGTH 33 i3c_master_config_t 主配置; i3c_master_transfer_t masterXfer; status_t 结果 = kStatus_Success; /* 将主时钟附加到 I3C,396MHz / 4 = 99MHz。*/ CLOCK_AttachClk(kMAIN_CLK_to_I3C_CLK); CLOCK_SetClkDiv(kCLOCK_DivI3cClk, 4); BOARD_InitBootPins(); BOARD_InitBootClocks(); BOARD_InitDebugConsole(); PRINTF("rnI3C board2board Interrupt example -- Master transfer.rn"); /* I3C模式:设置i3c master工作在I3C模式,向slave发送数据*/ / * txBuff中第一个数据为发送数据的数据长度。*/ g_master_txBuff[0] = I3C_DATA_LENGTH - 1U; 对于 (uint32_t i = 1U; i < I3C_DATA_LENGTH; i++) { g_master_txBuff = i - 1; } PRINTF("rn开始以I2C模式做I3C主控传输。rn"); PRINTF("Master 将发送数据:"); 对于 (uint32_t i = 0U; i < I3C_DATA_LENGTH - 1U; i++) { if (i % 8 == 0) { PRINTF("rn"); } PRINTF("0x%2x", g_master_txBuff[i + 1]); } PRINTF("rnrn"); I3C_MasterGetDefaultConfig(&masterConfig); masterConfig.baudRate_Hz.i2cBaud = EXAMPLE_I2C_BAUDRATE; masterConfig.baudRate_Hz.i3cPushPullBaud = 4000000U; masterConfig.baudRate_Hz.i3cOpenDrainBaud = 1500000U; masterConfig.enableOpenDrainStop = false; I3C_MasterInit(EXAMPLE_MASTER, &masterConfig, I3C_MASTER_CLOCK_FREQUENCY); /* 创建 I3C 句柄。*/ I3C_MasterTransferCreateHandle(EXAMPLE_MASTER, &g_i3c_m_handle, &masterCallback, NULL); memset(&masterXfer, 0, sizeof(masterXfer)); /* subAddress = 0x01, data = g_master_txBuff - 写入从机。 start + slaveaddress(w) + subAddress + data buffer 长度 + data buffer + stop*/ uint8_t deviceAddress = 0x01U; masterXfer.slaveAddress = I3C_MASTER_SLAVE_ADDR_7BIT; masterXfer.direction = kI3C_Write; masterXfer.busType = kI3C_TypeI2C; masterXfer.subaddress = (uint32_t)deviceAddress; masterXfer.subaddressSize = 1; masterXfer.data = g_master_txBuff; masterXfer.dataSize = I3C_DATA_LENGTH; masterXfer.flags = kI3C_TransferDefaultFlag; 结果 = I3C_MasterTransferNonBlocking(EXAMPLE_MASTER, &g_i3c_m_handle, &masterXfer); |
1974个成员聚集在这个小组
36587 浏览 0 评论
6033 浏览 1 评论
6262 浏览 1 评论
6949 浏览 0 评论
4330 浏览 0 评论
742浏览 2评论
721浏览 2评论
733浏览 2评论
810浏览 2评论
927浏览 2评论
GMT+8, 2025-3-5 12:19 , Processed in 1.190177 second(s), Total 74, Slave 58 queries .
