我注入了一个 256 位的 HMAC 秘密:
root@raspberrypi:~ # ssscli se05x readidlist sss :INFO :atr (Len=35) 01 A0 00 00 03 96 04 03 E8 00 FE 02 0B 03 E8 00 01 00 00 00 00 64 13 88 0A 00 65 53 45 30 35 31 00 00 00 sss :WARN :nxEnsure:'ret == SM_OK' failed. At Line:6971 Function:sss_se05x_TXn sss :WARN :Error in Se05x_API_ReadType. Further use of object may fail sss :WARN :nxEnsure:'ret == SM_OK' failed. At Line:6971 Function:sss_se05x_TXn Key-Id: 0Xa12 HMAC Size(Bits): 256它不会工作: root@raspberrypi:~ # ssscli sign --hashalgo SHA256 a12 input hmac sss :INFO :atr (Len=35) 01 A0 00 00 03 96 04 03 E8 00 FE 02 0B 03 E8 00 01 00 00 00 00 64 13 88 0A 00 65 53 45 30 35 31 00 00 00 sss :WARN :nxEnsure:'macOperation != kSE05x_MACAlgo_NA' failed. At Line:6489 Function:sss_se05x_mac_one_go ERROR:sss.symmetric:sss_mac_one_go FAILED ERROR:sss.sign:Received signature data is empty ERROR! Could not Sign from KeyID 0x00000A12输入文件: root@raspberrypi:~ # cat input 1672057238我们如何解决它? |
1866个成员聚集在这个小组
36190 浏览 0 评论
4287 浏览 0 评论
5916 浏览 1 评论
6660 浏览 0 评论
4110 浏览 0 评论
537浏览 2评论
529浏览 2评论
521浏览 2评论
602浏览 2评论
654浏览 2评论
GMT+8, 2024-9-22 01:02 , Processed in 0.954385 second(s), Total 76, Slave 60 queries .
