我有一个内核版本为 5.4.70 的 IMX8MP 处理器。
我正在尝试将相机连接到 csi0(相机 --> mipi csi 0 --> isi0 --> /dev/video0)。 在另一个输入(相机 --> mipi csi 1 --> isi0 --> /dev/video1)上,它可以在相同的设置下正常工作。 可能是什么问题呢? camera_0: camera_0_mipi@3e { compatible = "camera_0"; reg = <0x3e>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_csi0_rst>, <&pinctrl_csi0_pwn>; csi_id = <0>; reset-gpios = <&gpio3 19 GPIO_ACTIVE_LOW>; enable-gpios = <&gpio3 20 GPIO_ACTIVE_HIGH>; mipi_csi; status = "okay"; port { camera_mipi_0_ep: endpoint { bus-type = <4>; data-lanes = <1 2 3 4>; clock-lanes = <0>; remote-endpoint = <&mipi_csi0_ep>; }; }; }; camera_1: camera_1_mipi@3c { compatible = "camera_1"; reg = <0x3c>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_csi1_rst>, <&pinctrl_csi1_pwn>; csi_id = <1>; reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>; enable-gpios = <&gpio2 11 GPIO_ACTIVE_HIGH>; mipi_csi; status = "okay"; port { camera_mipi_1_ep: endpoint { bus-type = <4>; data-lanes = <1 2 3 4>; clock-lanes = <0>; remote-endpoint = <&mipi_csi1_ep>; }; }; }; &mipi_csi_0 { #address-cells = <1>; #size-cells = <0>; status = "okay"; port@0 { reg = <0>; mipi_csi0_ep: endpoint { remote-endpoint = <&camera_mipi_0_ep>; data-lanes = <4>; csis-hs-settle = <13>; csis-clk-settle=<2>; csis-wclk; }; }; }; &mipi_csi_1 { #address-cells = <1>; #size-cells = <0>; status = "okay"; port@1 { reg = <1>; mipi_csi1_ep: endpoint { remote-endpoint = <&camera_mipi_1_ep>; data-lanes = <4>; csis-hs-settle = <13>; csis-clk-settle=<2>; csis-wclk; }; }; }; &cameradev { status = "okay"; }; &isi_0 { status = "okay"; cap_device { status = "okay"; }; // m2m_device { // status = "okay"; // }; }; &isi_1 { status = "okay"; cap_device { status = "okay"; }; }; &isp_0 { status = "disabled"; }; &isp_1 { status = "disabled"; }; &dewarp_0 { status = "disabled"; }; |
1864个成员聚集在这个小组
36179 浏览 0 评论
4282 浏览 0 评论
5912 浏览 1 评论
6655 浏览 0 评论
4105 浏览 0 评论
530浏览 2评论
520浏览 2评论
515浏览 2评论
596浏览 2评论
647浏览 2评论
GMT+8, 2024-9-20 09:26 , Processed in 0.987263 second(s), Total 75, Slave 59 queries .
