主要错误发生在链接为主程序上, 这个问题卡了我四天了, 初学ESP-ADF不太懂,请大佬帮忙!
以下是编译的报错信息, 之前编译应该都是OK的, 就死在了链接环节, 好像是librecorder_engine.a录音引擎库,使用了get_wakenet_iface(), et_wakenet_coeff()以及VAD检测的一些函数,但在链接时未找到. 我如何操作才能让ESP_ADF中的Dueros示例编译通过呢? 谢谢各位大佬. [6/7] Linking CXX executable esp_dueros.elf FAILED: esp_dueros.elf cmd.exe /C "cd . && D:User.espressiftoolsxtensa-esp32-elfesp-2019r2-8.2.0xtensa-esp32-elfbinxtensa-esp32-elf-g++.exe -mlongcalls -Wno-frame-address -nostdlib @CMakeFilesesp_dueros.elf.rsp -o esp_dueros.elf && cd ." d:/user/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/User/Desktop/esp-adf/components/esp-adf-libs/recorder_engine/lib/esp32librecorder_engine.a(recorder_engine.c.obj):(.literal.rec_engine_task+0xe0): undefined reference to `get_wakenet_iface' d:/user/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/User/Desktop/esp-adf/components/esp-adf-libs/recorder_engine/lib/esp32librecorder_engine.a(recorder_engine.c.obj):(.literal.rec_engine_task+0xe4): undefined reference to `get_wakenet_coeff' d:/user/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/User/Desktop/esp-adf/components/esp-adf-libs/recorder_engine/lib/esp32librecorder_engine.a(recorder_engine.c.obj):(.literal.rec_engine_task+0xe8): undefined reference to `vad_create' d:/user/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/User/Desktop/esp-adf/components/esp-adf-libs/recorder_engine/lib/esp32librecorder_engine.a(recorder_engine.c.obj):(.literal.rec_engine_task+0xec): undefined reference to `vad_destroy' d:/user/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/User/Desktop/esp-adf/components/esp-adf-libs/recorder_engine/lib/esp32librecorder_engine.a(recorder_engine.c.obj):(.literal.rec_engine_task+0xf4): undefined reference to `vad_process' d:/user/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/User/Desktop/esp-adf/components/esp-adf-libs/recorder_engine/lib/esp32librecorder_engine.a(recorder_engine.c.obj): in function `rec_engine_task': /home/houhaiyan/esp-audio-adf-projects/esp-adf-libs-source/recorder_engine/recorder_engine.c:287: undefined reference to `get_wakenet_iface' d:/user/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: /home/houhaiyan/esp-audio-adf-projects/esp-adf-libs-source/recorder_engine/recorder_engine.c:299: undefined reference to `get_wakenet_coeff' d:/user/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: /home/houhaiyan/esp-audio-adf-projects/esp-adf-libs-source/recorder_engine/recorder_engine.c:307: undefined reference to `vad_create' d:/user/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: /home/houhaiyan/esp-audio-adf-projects/esp-adf-libs-source/recorder_engine/recorder_engine.c:642: undefined reference to `vad_destroy' d:/user/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: /home/houhaiyan/esp-audio-adf-projects/esp-adf-libs-source/recorder_engine/recorder_engine.c:449: undefined reference to `vad_process' |
198个成员聚集在这个小组
加入小组482 浏览 1 评论
1780 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
383浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
177浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
223浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
575浏览 2评论
268浏览 2评论
GMT+8, 2025-3-6 02:11 , Processed in 0.670687 second(s), Total 42, Slave 37 queries .
