编译烧录到开发板程序运行不起来,报错日志如下,谁知道什么原因呢?
Code: Select all [/ rst:0x1 (POWERON_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:6612 load:0x40078000,len:14780 load:0x40080400,len:3792 entry 0x40080694 [0;32mI (27) boot: ESP-IDF v4.4-dirty 2nd stage bootloader[0m [0;32mI (27) boot: compile time 13:43:12[0m [0;32mI (27) boot: chip revision: 1[0m [0;32mI (30) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m [0;32mI (37) boot.esp32: SPI Speed : 40MHz[0m [0;32mI (42) boot.esp32: SPI Mode : DIO[0m [0;32mI (46) boot.esp32: SPI Flash Size : 2MB[0m [0;32mI (51) boot: Enabling RNG early entropy source...[0m [0;32mI (56) boot: Partition Table:[0m [0;32mI (60) boot: ## Label Usage Type ST Offset Length[0m [0;32mI (67) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m [0;32mI (75) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m [0;32mI (82) boot: 2 factory factory app 00 00 00010000 00100000[0m [0;32mI (90) boot: End of partition table[0m [0;32mI (94) boot_comm: chip revision: 1, min. application chip revision: 0[0m [0;32mI (101) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=13a54h ( 80468) map[0m [0;32mI (139) esp_image: segment 1: paddr=00023a7c vaddr=3ffb0000 size=02530h ( 9520) load[0m [0;32mI (143) esp_image: segment 2: paddr=00025fb4 vaddr=40080000 size=0a064h ( 41060) load[0m [0;32mI (161) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=3212ch (205100) map[0m [0;32mI (236) esp_image: segment 4: paddr=00062154 vaddr=4008a064 size=05918h ( 22808) load[0m [0;32mI (245) esp_image: segment 5: paddr=00067a74 vaddr=50000000 size=00010h ( 16) load[0m [0;32mI (253) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (253) boot: Disabling RNG early entropy source...[0m [0;32mI (267) cpu_start: Pro cpu up.[0m [0;32mI (267) cpu_start: Starting app cpu, entry point is 0x400813ec[0m [0;32mI (0) cpu_start: App cpu up.[0m [0;32mI (281) cpu_start: Pro cpu start user code[0m [0;32mI (281) cpu_start: cpu freq: 160000000[0m [0;32mI (281) cpu_start: Application information:[0m [0;32mI (285) cpu_start: Project name: raw_pipeline_demo[0m [0;32mI (291) cpu_start: App version: v2.2-82-g184ed67-dirty[0m [0;32mI (298) cpu_start: Compile time: Jul 21 2022 13:42:40[0m [0;32mI (304) cpu_start: ELF file SHA256: d62004de61d10486...[0m [0;32mI (310) cpu_start: ESP-IDF: v4.4-dirty[0m [0;32mI (315) heap_init: Initializing. RAM available for dynamic allocation:[0m [0;32mI (322) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM[0m [0;32mI (328) heap_init: At 3FFB3050 len 0002CFB0 (179 KiB): DRAM[0m [0;32mI (334) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[0m [0;32mI (341) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m [0;32mI (347) heap_init: At 4008F97C len 00010684 (65 KiB): IRAM[0m [0;32mI (355) spi_flash: detected chip: generic[0m [0;32mI (358) spi_flash: flash io: dio[0m [0;33mW (362) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.[0m [0;32mI (376) cpu_start: Starting scheduler on PRO CPU.[0m [0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m [0;32mI (386) PIPELINE_PARTIAL_EXAMPLE: [ 1 ] Mount sdcard[0m [0;32mI (896) PIPELINE_PARTIAL_EXAMPLE: [ 2 ] Start codec chip[0m [0;31mE (896) gpio: gpio_install_isr_service(449): GPIO isr service already installed[0m [0;32mI (916) PIPELINE_PARTIAL_EXAMPLE: [3.0] Create i2s stream to write data to codec chip[0m [0;32mI (916) PIPELINE_PARTIAL_EXAMPLE: [3.1] Create mp3 decoder to decode mp3 data[0m [0;32mI (926) PIPELINE_PARTIAL_EXAMPLE: [3.2] Associate custom read callback to mp3 decoder[0m [0;32mI (926) PIPELINE_PARTIAL_EXAMPLE: [3.3] Create a ringbuffer and insert it between mp3 decoder and i2s writer[0m [0;32mI (946) PIPELINE_PARTIAL_EXAMPLE: [ 4 ] Start audio elements[0m Error opening file [0;31mE (986) AUDIO_ELEMENT: IN-[mp3] AEL_STATUS_ERROR_INPUT[0m [0;31mE (986) MP3_DECODER: failed to read audio data (line 118)[0m [0;31mE (996) AUDIO_ELEMENT: [mp3] AEL_STATUS_ERROR_OPEN,-1[0m [0;33mW (996) AUDIO_ELEMENT: [mp3] audio_element_on_cmd_error,7[0m [0;33mW (1006) AUDIO_ELEMENT: IN-[iis] AEL_IO_ABORT[0m ] |
180个成员聚集在这个小组
加入小组448 浏览 1 评论
1443 浏览 1 评论
614浏览 6评论
510浏览 5评论
488浏览 5评论
491浏览 4评论
477浏览 4评论
GMT+8, 2025-1-31 15:59 , Processed in 0.563324 second(s), Total 40, Slave 35 queries .
