40081410
I (0) cpu_start: App cpu up. I (304) cpu_start: Pro cpu start user code I (304) cpu_start: cpu freq: 160000000 I (304) cpu_start: Application information: I (308) cpu_start: Project name: play_sdcard_mp3_control I (315) cpu_start: App version: v2.4-68-gf44c535-dirty I (321) cpu_start: Compile time: Aug 4 2022 10:13:56 I (327) cpu_start: ELF file SHA256: 3ee9725b45d83e73... I (333) cpu_start: ESP-IDF: v4.4 I (338) heap_init: Initializing. RAM available for dynamic allocation: I (345) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (351) heap_init: At 3FFB30A0 len 0002CF60 (179 KiB): DRAM I (357) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (363) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (370) heap_init: At 4008FA8C len 00010574 (65 KiB): IRAM I (377) spi_flash: detected chip: generic I (381) spi_flash: flash io: dio W (385) spi_flash: Detected size(8192k) larger than the size in the binary image header(4096k). Using the size in the binary image header. I (399) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (409) SDCARD_MP3_CONTROL_EXAMPLE: [1.0] Initialize peripherals management I (419) SDCARD_MP3_CONTROL_EXAMPLE: [1.1] Initialize and start peripherals W (449) PERIPH_TOUCH: _touch_init I (929) SDCARD_MP3_CONTROL_EXAMPLE: [1.2] Set up a sdcard playlist and scan sdcard music save to it I (979) SDCARD_MP3_CONTROL_EXAMPLE: [ 2 ] Start codec chip E (979) gpio: gpio_install_isr_service(449): GPIO isr service already installed I (1019) SDCARD_MP3_CONTROL_EXAMPLE: [ 3 ] Create and start input key service I (1019) SDCARD_MP3_CONTROL_EXAMPLE: [4.0] Create audio pipeline for playback I (1029) SDCARD_MP3_CONTROL_EXAMPLE: [4.1] Create i2s stream to write data to codec chip I (1049) SDCARD_MP3_CONTROL_EXAMPLE: [4.2] Create mp3 decoder to decode mp3 file I (1049) SDCARD_MP3_CONTROL_EXAMPLE: [4.3] Create resample filter I (1049) SDCARD_MP3_CONTROL_EXAMPLE: [4.4] Create fatfs stream to read data from sdcard I (1059) SDCARD_MP3_CONTROL_EXAMPLE: [4.5] Register all elements to audio pipeline I (1069) SDCARD_MP3_CONTROL_EXAMPLE: [4.6] Link it together [sdcard]-->fatfs_stream-->mp3_decoder-->resample-->i2s_stream-->[codec_chip] I (1079) SDCARD_MP3_CONTROL_EXAMPLE: [5.0] Set up event listener I (1099) SDCARD_MP3_CONTROL_EXAMPLE: [5.1] Listen for all pipeline events W (1099) SDCARD_MP3_CONTROL_EXAMPLE: [ 6 ] Press the keys to control music player: W (1099) SDCARD_MP3_CONTROL_EXAMPLE: [Play] to start, pause and resume, [Set] next song. W (1109) SDCARD_MP3_CONTROL_EXAMPLE: [Vol-] or [Vol+] to adjust volume. I (9749) SDCARD_MP3_CONTROL_EXAMPLE: [ * ] input key id is 3 I (9749) SDCARD_MP3_CONTROL_EXAMPLE: [ * ] [Play] input key event I (9749) SDCARD_MP3_CONTROL_EXAMPLE: [ * ] Starting audio pipeline E (9859) FIR_RESAMPLE: failed to allocate p_out buffer.size 35666 line 2010 E (9859) RSP_FILTER: Failed to create the resample handler E (9859) AUDIO_ELEMENT: [filter] AEL_STATUS_ERROR_OPEN,-1 W (9869) AUDIO_ELEMENT: [filter] audio_element_on_cmd_error,7 W (9869) AUDIO_ELEMENT: IN-[i2s] AEL_IO_ABORT W (9889) AUDIO_ELEMENT: OUT-[mp3] AEL_IO_ABORT W (9889) MP3_DECODER: output aborted -3 I (9899) SDCARD_MP3_CONTROL_EXAMPLE: [ * ] Received music info from mp3 decoder, sample_rates=44100, bits=16, ch=2 |
172个成员聚集在这个小组
加入小组431 浏览 1 评论
1299 浏览 1 评论
599浏览 6评论
498浏览 5评论
481浏览 5评论
480浏览 4评论
464浏览 4评论
GMT+8, 2025-1-13 05:29 , Processed in 0.673869 second(s), Total 42, Slave 37 queries .
