设置编译ESP32S3 开发板是KORVO2编译时出现下面错误信息。
In file included from C:/Espressif/frameworks/esp-adf/components/audio_recorder/include/recorder_sr.h:32, from C:/Espressif/frameworks/esp-adf/examples/advanced_examples/esp_dispatcher_dueros/main/audio_setup.c:52: C:/Espressif/frameworks/esp-adf/components/audio_recorder/include/ch_sort.h: In function 'ch_sort_16bit_2ch': C:/Espressif/frameworks/esp-adf/components/audio_recorder/include/ch_sort.h:88:9: error: implicit declaration of function 'memcpy' [-Werror=implicit-function-declaration] memcpy(o_buf, i_buf, len); ^~~~~~ C:/Espressif/frameworks/esp-adf/components/audio_recorder/include/ch_sort.h:88:9: warning: incompatible implicit declaration of built-in function 'memcpy' C:/Espressif/frameworks/esp-adf/components/audio_recorder/include/ch_sort.h:88:9: note: include ' C:/Espressif/frameworks/esp-adf/components/audio_recorder/include/ch_sort.h:1:1: +#include /* C:/Espressif/frameworks/esp-adf/components/audio_recorder/include/ch_sort.h:88:9: memcpy(o_buf, i_buf, len); ^~~~~~ cc1.exe: some warnings being treated as errors [1385/1442] Building C object esp-idf/wifi_service/CMakeFiles/__idf_wifi_service.dir/blufi_config/blufi_config.c.obj ninja: build stopped: subcommand failed. ninja failed with exit code 1 什么原因,怎么解决。 |
198个成员聚集在这个小组
加入小组482 浏览 1 评论
1780 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
383浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
177浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
223浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
575浏览 2评论
268浏览 2评论
GMT+8, 2025-3-6 02:46 , Processed in 0.652678 second(s), Total 42, Slave 37 queries .
