在初始化ST7789并口驱动时,一直卡死了在了队列接收中:ESP_LOGI("i2s_write_data","xQueueReceive start1") 和ESP_LOGI("i2s_write_data","xQueueReceive end1")之间的 xQueueReceive(i2s_lcd_obj->event_queue, (void *)&event, portMAX_DELAY)中
代码如下: static void i2s_write_data(i2s_lcd_obj_t *i2s_lcd_obj, uint8_t *data, size_t len) { int event = 0; int x = 0, y = 0, left = 0, cnt = 0; if (len <= 0) { ESP_LOGE(TAG, "wrong len!"); return; } lcd_dma_set_int(i2s_lcd_obj); uint32_t half_buffer_size = i2s_lcd_obj->dma_half_buffer_size; cnt = len / half_buffer_size; // Start signal xQueueSend(i2s_lcd_obj->event_queue, &event, 0); // Process a complete piece of data, ping-pong operation for (x = 0; x < cnt; x++) { uint8_t *out = (uint8_t*)i2s_lcd_obj->dma[(x % 2) * i2s_lcd_obj->dma_half_node_cnt].buf; uint8_t *in = data; if (i2s_lcd_obj->swap_data) { uint8_t *out1 = out + 1; uint8_t *in1 = in + 1; for (y = 0; y < half_buffer_size;) { out1[y] = in[y]; out[y] = in1[y]; y += 2; out1[y] = in[y]; out[y] = in1[y]; y += 2; } } else { memcpy(out, in, half_buffer_size); } data += half_buffer_size; xQueueReceive(i2s_lcd_obj->event_queue, (void *)&event, portMAX_DELAY); lcd_i2s_start(i2s_lcd_obj->i2s_dev, ((uint32_t)&i2s_lcd_obj->dma[(x % 2) * i2s_lcd_obj->dma_half_node_cnt]) & 0xfffff, half_buffer_size); } left = len % half_buffer_size; // Process remaining incomplete segment data if (left) { uint8_t *out = (uint8_t*)i2s_lcd_obj->dma[(x % 2) * i2s_lcd_obj->dma_half_node_cnt].buf; uint8_t *in = data; cnt = left - left % 2; if (cnt) { if (i2s_lcd_obj->swap_data) { for (y = 0; y < cnt; y+=2) { out[y+1] = in[y+0]; out[y+0] = in[y+1]; } } else { memcpy(out, in, cnt); } } if (left % 2) { out[cnt] = in[cnt]; } lcd_dma_set_left(i2s_lcd_obj, x, left); xQueueReceive(i2s_lcd_obj->event_queue, (void *)&event, portMAX_DELAY); lcd_i2s_start(i2s_lcd_obj->i2s_dev, ((uint32_t)&i2s_lcd_obj->dma[(x % 2) * i2s_lcd_obj->dma_half_node_cnt]) & 0xfffff, left); } ESP_LOGI("i2s_write_data","xQueueReceive start1"); xQueueReceive(i2s_lcd_obj->event_queue, (void *)&event, portMAX_DELAY); ESP_LOGI("i2s_write_data","xQueueReceive end1"); } 有没有遇到这种情况的啊? |
180个成员聚集在这个小组
加入小组453 浏览 1 评论
1452 浏览 1 评论
618浏览 6评论
515浏览 5评论
495浏览 5评论
496浏览 4评论
486浏览 4评论
GMT+8, 2025-2-4 10:04 , Processed in 0.578297 second(s), Total 40, Slave 35 queries .
