在编译esp-at源码时,出现如下的错误提示;
# make fatal: 不是一个 git 仓库(或者任何父目录):.git Makefile:36: There is no module_config/module_wroom-32,Using module_config/module_esp32_default /home/jizhe/esp/esp-at-2.0.0.0_esp32/tools/mkfatfs/Makefile.projbuild:13: 警告:覆盖关于目标“clean”的配方 /home/jizhe/esp/esp-at-2.0.0.0_esp32/esp-idf/components/app_update/Makefile.projbuild:48: 警告:忽略关于目标“clean”的旧配方 Toolchain path: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5 Compiler version: 5.2.0 Python requirements from E:/msys32_at_idf_3.3_test/home/jizhe/esp/esp-at-2.0.0.0_esp32/esp-idf/requirements.txt are satisfied. App "esp-at" version: ESP-AT Generating esp32.project.ld Traceback (most recent call last): File "E:/msys32_at_idf_3.3_test/home/jizhe/esp/esp-at-2.0.0.0_esp32/esp-idf/tools/ldgen/ldgen.py", line 113, in main() File "E:/msys32_at_idf_3.3_test/home/jizhe/esp/esp-at-2.0.0.0_esp32/esp-idf/tools/ldgen/ldgen.py", line 96, in main sdkconfig = SDKConfig(kconfig_file, config_file, args.env) File "E:/msys32_at_idf_3.3_test/home/jizhe/esp/esp-at-2.0.0.0_esp32/esp-idf/tools/ldgen/sdkconfig.py", line 56, in __init__ self.config = kconfiglib.Kconfig(kconfig_file.name) File "E:/msys32_at_idf_3.3_test/home/jizhe/esp/esp-at-2.0.0.0_esp32/esp-idf/tools/kconfig_new/kconfiglib.py", line 656, in __init__ self.top_node) # prev_node File "E:/msys32_at_idf_3.3_test/home/jizhe/esp/esp-at-2.0.0.0_esp32/esp-idf/tools/kconfig_new/kconfiglib.py", line 1583, in _parse_block self._enter_file(sourced_file) File "E:/msys32_at_idf_3.3_test/home/jizhe/esp/esp-at-2.0.0.0_esp32/esp-idf/tools/kconfig_new/kconfiglib.py", line 1167, in _enter_file .format(self._filename, self._linenr, e.message)) IOError: E:/msys32_at_idf_3.3_test/home/jizhe/esp/esp-at-2.0.0.0_esp32/esp-idf/Kconfig:59: Could not open 'E:msys32_at_idf_3.3_testhomejizheespesp-at-2.0.0.0_esp32esp-idfcomponentsapp_updateKconfig.projbuild' (ENOENT: No such file or directory). Perhaps the $srctree environment variable (which was unset) is set incorrectly. Note that the current value of $srctree is saved when the Kconfig instance is created (for consistency and to cleanly separate instances). Also note that e.g. $FOO in a 'source' statement does not refer to the environment variable FOO, but rather to the Kconfig Symbol FOO (which would commonly have 'option env="FOO"' in its definition). make: *** [/home/jizhe/esp/esp-at-2.0.0.0_esp32/esp-idf/components/esp32/Makefile.projbuild:51:/home/jizhe/esp/esp-at-2.0.0.0_esp32/build/esp32/esp32.project.ld] 错误 1 提示未能找到该文件,看输出的日志,个人认为是文件路径中斜杠符号丢失所致,请问这个该如何解决呢。 编译环境:WIN7 64bit, MSYS2 Toolchain path: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5 Compiler version: 5.2.0 ESP-IDF: V3.3 AT源码:esp-at-2.0.0.0_esp32 |
180个成员聚集在这个小组
加入小组453 浏览 1 评论
1452 浏览 1 评论
618浏览 6评论
515浏览 5评论
494浏览 5评论
496浏览 4评论
486浏览 4评论
GMT+8, 2025-2-3 20:01 , Processed in 0.607112 second(s), Total 42, Slave 37 queries .
