编译amazon_alexa,主板选择audio_board_lyratd_dspg,最后Link时候报错。错误信息如下:
[1407/1409] Linking CXX executable avs.elf FAILED: avs.elf cmd.exe /C "cd . && C:Espressiftoolsxtensa-esp32-elfesp-2021r2-patch3-8.4.0xtensa-esp32-elfbinxtensa-esp32-elf-g++.exe -mlongcalls -Wno-frame-address @CMakeFilesavs.elf.rsp -o avs.elf && cd ." c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: avs.elf section `.iram0.text' will not fit in region `iram0_0_seg' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: IRAM0 segment data does not fit. c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: region `iram0_0_seg' overflowed by 2732 bytes c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/esp-ssdp/lib/libesp-ssdp.a(lssdp.c.obj):(.literal.trim_spaces+0x0): undefined reference to `__locale_ctype_ptr' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/esp-ssdp/lib/libesp-ssdp.a(lssdp.c.obj):(.text.trim_spaces+0x20): undefined reference to `__locale_ctype_ptr' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/esp-ssdp/lib/libesp-ssdp.a(lssdp.c.obj):(.text.trim_spaces+0x38): undefined reference to `__locale_ctype_ptr' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/esp-ssdp/lib/libesp-ssdp.a(lssdp.c.obj):(.text.trim_spaces+0x51): undefined reference to `__locale_ctype_ptr' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/esp-ssdp/lib/libesp-ssdp.a(lssdp.c.obj):(.text.trim_spaces+0x6a): undefined reference to `__locale_ctype_ptr' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/voice_assistant/lib/libavs.a(dialog.c.obj):(.literal.dialog_sm_thread+0x30): undefined reference to `xTaskNotify' c:/espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:/esp-va-sdk/components/voice_assistant/lib/libavs.a(dialog.c.obj):(.text.dialog_sm_thread+0xae): undefined reference to `xTaskNotify' collect2.exe: error: ld returned 1 exit status ninja: build stopped: subcommand failed. ninja failed with exit code 1 |
179个成员聚集在这个小组
加入小组441 浏览 1 评论
1419 浏览 1 评论
610浏览 6评论
506浏览 5评论
487浏览 5评论
490浏览 4评论
474浏览 4评论
GMT+8, 2025-1-26 15:18 , Processed in 0.655027 second(s), Total 39, Slave 34 queries .
