## Environment
- Development Kit: 自制板卡 - Module or chip used: 安信可ESP-C3-13模组 - IDF version: ESP-IDF v4.4.1-dirty - Build System: idf.py - Operating System: 在win10主机的vmware16中运行的Ubuntu 20.04.4 LTS - Using an IDE?: No - Power Supply:USB ## Problem Description 我最近在使用esp32c3的USB-JTAG调试系统,却发现esp32c3的usb-cdc串口可以正常工作,但却无法正常调试。经我排查发现,发现系统可能就只加载了usb串口设备,没有加载USB-JTAG设备。 ## Debug Logs 使用openocd 调试esp32c3 使用 USB-JATG,发生以下错误,没有找到JATG设备 ```cjia@cjia-com:~$ openocd -f board/esp32c3-builtin.cfg Open On-Chip Debugger v0.11.0-esp32-20211220 (2021-12-20-15:42) Licensed under GNU GPL v2 For bug reports, read Info : only one transport option; autoselect 'jtag' Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001 Info : esp_usb_jtag: capabilities descriptor set to 0x2000 Warn : Transport "jtag" was already selected Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Error: libusb_open() failed with LIBUSB_ERROR_ACCESS Error: esp_usb_jtag: could not find or open device! ``` 这是 lsusb ,发现可以找到Espressif USB JTAG/serial debug unit ![image](https://user-images.githubusercontent.c ... e287ed.png) - 这是系统日志 [系统日志.txt](https://github.com/espressif/esp-idf/fi ... efault.txt) 我截取了一些你们可能感兴趣的部分 ``` [ 2.177982] usb 3-2: new full-speed USB device number 3 using xhci_hcd [ 2.541285] usb 3-2: New USB device found, idVendor=303a, idProduct=1001, bcdDevice= 1.01 [ 2.541291] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.541292] usb 3-2: Product: USB JTAG/serial debug unit [ 2.541293] usb 3-2: Manufacturer: Espressif [ 2.541295] usb 3-2: SerialNumber: 84:F7:03:54:55:E8 [ 545.584525] usb 3-2: USB disconnect, device number 3 [ 560.656569] usb 3-2: new full-speed USB device number 6 using xhci_hcd [ 561.010461] usb 3-2: New USB device found, idVendor=303a, idProduct=1001, bcdDevice= 1.01 [ 561.010467] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 561.010468] usb 3-2: Product: USB JTAG/serial debug unit [ 561.010469] usb 3-2: Manufacturer: Espressif [ 561.010471] usb 3-2: SerialNumber: 84:F7:03:54:55:E8 [ 561.016525] cdc_acm 3-2:1.0: ttyACM0: USB ACM device ``` 我发现似乎只加载了USB ACM device |
142个成员聚集在这个小组
加入小组529浏览 6评论
446浏览 5评论
428浏览 5评论
424浏览 4评论
401浏览 4评论
GMT+8, 2024-11-10 15:35 , Processed in 0.535334 second(s), Total 43, Slave 38 queries .
