log如下:
ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd0108,len:0x1714 load:0x403b6000,len:0xb7c load:0x403ba000,len:0x3094 entry 0x403b6248 I (24) boot: ESP-IDF v4.4.1-dirty 2nd stage bootloader I (25) boot: compile time 10:52:31 I (25) boot: chip revision: 0 I (27) boot.esp32s3: Boot SPI Speed : 80MHz I (32) boot.esp32s3: SPI Mode : DIO I (36) boot.esp32s3: SPI Flash Size : 2MB I (41) boot: Enabling RNG early entropy source... I (47) boot: Partition Table: I (50) boot: ## Label Usage Type ST Offset Length I (57) boot: 0 nvs WiFi data 01 02 00009000 00006000I (65) boot: 1 phy_init RF data 01 01 0000f000 00001000I (72) boot: 2 factory factory app 00 00 00010000 00100000I (80) boot: End of partition table I (84) esp_image: segment 0: paddr=00010020 vaddr=3c020020 size=07f50h ( 32592) map I (98) esp_image: segment 1: paddr=00017f78 vaddr=3fc91e60 size=02774h ( 10100) load I (103) esp_image: segment 2: paddr=0001a6f4 vaddr=40374000 size=05924h ( 22820) load I (114) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=1778ch ( 96140) map I (135) esp_image: segment 4: paddr=000377b4 vaddr=40379924 size=08530h ( 34096) load I (143) esp_image: segment 5: paddr=0003fcec vaddr=50000000 size=00010h ( 16) load I (143) esp_image: segment 6: paddr=0003fd04 vaddr=600fe000 size=00028h ( 40) load I (155) boot: Loaded app from partition at offset 0x10000 I (155) boot: Disabling RNG early entropy source... I (172) cpu_start: Pro cpu up. I (172) cpu_start: Starting app cpu, entry point is 0x403751e8 0x403751e8: call_start_cpu1 at H:/ESP32/Espressif/frameworks/esp-idf-v4.4.1/esp-idf-v4.4.1/components/esp_system/port/cpu_start.c:160 I (0) cpu_start: App cpu up. I (186) cpu_start: Pro cpu start user code I (186) cpu_start: cpu freq: 160000000 I (186) cpu_start: Application information: I (189) cpu_start: Project name: deep_sleep I (194) cpu_start: App version: 1 I (199) cpu_start: Compile time: Oct 19 2022 10:51:47 I (205) cpu_start: ELF file SHA256: d221e5cbd6a9a6da... I (211) cpu_start: ESP-IDF: v4.4.1-dirty I (216) heap_init: Initializing. RAM available for dynamic allocation: I (223) heap_init: At 3FC94FD8 len 0004B028 (300 KiB): D/IRAM I (230) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM I (236) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM I (243) heap_init: At 600FE028 len 00001FC8 (7 KiB): RTCRAM I (249) spi_flash: detected chip: generic I (254) spi_flash: flash io: dio W (257) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header. I (271) sleep: Configure to isolate all GPIO pins in sleep state I (278) sleep: Enable automatic switching of GPIO sleep configuration I (285) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. core 0: 01 core 1: 01 Not a deep sleep reset Enabling EXT1 wakeup on pins GPIO2, GPIO4 Entering deep sleep ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x1 (POWERON),boot:0xb (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd0108,len:0x1714 load:0x403b6000,len:0xb7c load:0x403ba000,len:0x3094 entry 0x403b6248 I (24) boot: ESP-IDF v4.4.1-dirty 2nd stage bootloader I (25) boot: compile time 10:52:31 I (25) boot: chip revision: 0 I (27) boot.esp32s3: Boot SPI Speed : 80MHz I (32) boot.esp32s3: SPI Mode : DIO I (36) boot.esp32s3: SPI Flash Size : 2MB I (41) boot: Enabling RNG early entropy source... I (47) boot: Partition Table: I (50) boot: ## Label Usage Type ST Offset Length I (57) boot: 0 nvs WiFi data 01 02 00009000 00006000I (65) boot: 1 phy_init RF data 01 01 0000f000 00001000I (72) boot: 2 factory factory app 00 00 00010000 00100000I (80) boot: End of partition table I (84) esp_image: segment 0: paddr=00010020 vaddr=3c020020 size=07f50h ( 32592) map I (98) esp_image: segment 1: paddr=00017f78 vaddr=3fc91e60 size=02774h ( 10100) load I (103) esp_image: segment 2: paddr=0001a6f4 vaddr=40374000 size=05924h ( 22820) load I (114) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=1778ch ( 96140) map I (135) esp_image: segment 4: paddr=000377b4 vaddr=40379924 size=08530h ( 34096) load I (143) esp_image: segment 5: paddr=0003fcec vaddr=50000000 size=00010h ( 16) load I (143) esp_image: segment 6: paddr=0003fd04 vaddr=600fe000 size=00028h ( 40) load I (155) boot: Loaded app from partition at offset 0x10000 I (155) boot: Disabling RNG early entropy source... I (172) cpu_start: Pro cpu up. I (172) cpu_start: Starting app cpu, entry point is 0x403751e8 0x403751e8: call_start_cpu1 at H:/ESP32/Espressif/frameworks/esp-idf-v4.4.1/esp-idf-v4.4.1/components/esp_system/port/cpu_start.c:160 I (0) cpu_start: App cpu up. I (186) cpu_start: Pro cpu start user code I (186) cpu_start: cpu freq: 160000000 I (186) cpu_start: Application information: I (189) cpu_start: Project name: deep_sleep I (194) cpu_start: App version: 1 I (199) cpu_start: Compile time: Oct 19 2022 10:51:47 I (205) cpu_start: ELF file SHA256: d221e5cbd6a9a6da... I (211) cpu_start: ESP-IDF: v4.4.1-dirty I (216) heap_init: Initializing. RAM available for dynamic allocation: I (223) heap_init: At 3FC94FD8 len 0004B028 (300 KiB): D/IRAM I (230) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM I (236) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM I (243) heap_init: At 600FE028 len 00001FC8 (7 KiB): RTCRAM I (249) spi_flash: detected chip: generic I (254) spi_flash: flash io: dio W (257) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header. I (271) sleep: Configure to isolate all GPIO pins in sleep state I (278) sleep: Enable automatic switching of GPIO sleep configuration I (285) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. core 0: 01 core 1: 01 Not a deep sleep reset Enabling EXT1 wakeup on pins GPIO2, GPIO4 Entering deep sleep 貌似是触发ext1唤醒时会导致这个问题,但不确定。 代码如下: #include #include #include #include "sdkconfig.h" #include "freertos/FreeRTOS.h" #include "freertos/task.h" #include "esp_sleep.h" #include "esp_log.h" #include "driver/rtc_io.h" #include "rom/rtc.h" void app_main(void) { printf("core 0: %02xtcore 1: %02xrn", rtc_get_reset_reason(0), rtc_get_reset_reason(1)); switch (esp_sleep_get_wakeup_cause()) { #ifdef CONFIG_EXAMPLE_EXT1_WAKEUP case ESP_SLEEP_WAKEUP_EXT1: { uint64_t wakeup_pin_mask = esp_sleep_get_ext1_wakeup_status(); if (wakeup_pin_mask != 0) { int pin = __builtin_ffsll(wakeup_pin_mask) - 1; printf("Wake up from GPIO %dn", pin); } else { printf("Wake up from GPIOn"); } break; } #endif // CONFIG_EXAMPLE_EXT1_WAKEUP case ESP_SLEEP_WAKEUP_UNDEFINED: default: printf("Not a deep sleep resetn"); } vTaskDelay(1000 / portTICK_PERIOD_MS); #ifdef CONFIG_EXAMPLE_EXT1_WAKEUP const int ext_wakeup_pin_1 = 2; const uint64_t ext_wakeup_pin_1_mask = 1ULL << ext_wakeup_pin_1; const int ext_wakeup_pin_2 = 4; const uint64_t ext_wakeup_pin_2_mask = 1ULL << ext_wakeup_pin_2; printf("Enabling EXT1 wakeup on pins GPIO%d, GPIO%dn", ext_wakeup_pin_1, ext_wakeup_pin_2); esp_sleep_enable_ext1_wakeup(ext_wakeup_pin_1_mask | ext_wakeup_pin_2_mask, ESP_EXT1_WAKEUP_ANY_HIGH); #endif // CONFIG_EXAMPLE_EXT1_WAKEUP printf("Entering deep sleepn"); esp_deep_sleep_start(); } 目前是esp-idf 4.4.1中会有这样的问题,但esp-idf4.4.2里则可以正常运行,我在github中4.4.2的更新中没看到有关于此的记录,如果有大佬知道还望告知我一下是为什么。 |
179个成员聚集在这个小组
加入小组440 浏览 1 评论
1398 浏览 1 评论
608浏览 6评论
506浏览 5评论
487浏览 5评论
489浏览 4评论
472浏览 4评论
GMT+8, 2025-1-24 00:50 , Processed in 0.894223 second(s), Total 74, Slave 58 queries .
