I (364) esp_eth.netif.glue: ethernet attached to netif
I (374) eth_example: Ethernet Started I (2374) eth_example: Ethernet Link Up I (2374) eth_example: Ethernet HW Addr 02:00:00:12:34:56 I (2374) esp_netif_handlers: eth ip: 192.168.2.202, mask: 255.255.255.0, gw: 192.168.2.1 I (2374) eth_example: Ethernet Got IP Address I (2384) eth_example: ~~~~~~~~~~~ I (2384) eth_example: ETHIP:192.168.2.202 I (2394) eth_example: ETHMASK:255.255.255.0 I (2394) eth_example: ETHGW:192.168.2.1 I (2404) eth_example: ~~~~~~~~~~~ E (2734) spi_master: check_trans_valid(694): txdata transfer > host maximum E (2734) w5500-mac: w5500_read(103): spi transmit failed E (2744) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (2744) w5500-mac: emac_w5500_receive(555): read payload failed, len=20734, offset=156 E (8294) spi_master: check_trans_valid(694): txdata transfer > host maximum E (8294) w5500-mac: w5500_read(103): spi transmit failed E (8294) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (8304) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (8304) spi_master: check_trans_valid(694): txdata transfer > host maximum E (8314) w5500-mac: w5500_read(103): spi transmit failed E (8324) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (8324) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (8574) spi_master: check_trans_valid(694): txdata transfer > host maximum E (8574) w5500-mac: w5500_read(103): spi transmit failed E (8584) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (8584) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (8724) spi_master: check_trans_valid(694): txdata transfer > host maximum E (8724) w5500-mac: w5500_read(103): spi transmit failed E (8724) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (8724) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (8774) spi_master: check_trans_valid(694): txdata transfer > host maximum E (8774) w5500-mac: w5500_read(103): spi transmit failed E (8774) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (8784) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (8794) spi_master: check_trans_valid(694): txdata transfer > host maximum E (8804) w5500-mac: w5500_read(103): spi transmit failed E (8804) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (8814) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (8824) spi_master: check_trans_valid(694): txdata transfer > host maximum E (8834) w5500-mac: w5500_read(103): spi transmit failed E (8834) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (8844) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (8914) spi_master: check_trans_valid(694): txdata transfer > host maximum E (8914) w5500-mac: w5500_read(103): spi transmit failed E (8914) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (8924) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (8934) spi_master: check_trans_valid(694): txdata transfer > host maximum E (8944) w5500-mac: w5500_read(103): spi transmit failed E (8944) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (8954) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (8964) spi_master: check_trans_valid(694): txdata transfer > host maximum E (8974) w5500-mac: w5500_read(103): spi transmit failed E (8974) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (8984) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (8994) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9004) w5500-mac: w5500_read(103): spi transmit failed E (9004) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (9014) w5500-mac: emac_w5500_receive(555): read payload failed, len=13411, offset=5318 E (9204) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9204) w5500-mac: w5500_read(103): spi transmit failed E (9204) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (9214) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (9254) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9254) w5500-mac: w5500_read(103): spi transmit failed E (9254) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (9264) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (9284) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9284) w5500-mac: w5500_read(103): spi transmit failed E (9284) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (9294) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (9304) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9314) w5500-mac: w5500_read(103): spi transmit failed E (9314) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (9324) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (9424) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9424) w5500-mac: w5500_read(103): spi transmit failed E (9424) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (9434) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (9574) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9574) w5500-mac: w5500_read(103): spi transmit failed E (9574) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (9584) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (9774) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9774) w5500-mac: w5500_read(103): spi transmit failed E (9774) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (9784) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (9824) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9824) w5500-mac: w5500_read(103): spi transmit failed E (9824) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (9834) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (9944) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9944) w5500-mac: w5500_read(103): spi transmit failed E (9944) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (9954) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 E (9994) spi_master: check_trans_valid(694): txdata transfer > host maximum E (9994) w5500-mac: w5500_read(103): spi transmit failed E (9994) w5500-mac: w5500_read_buffer(191): read RX buffer failed E (10004) w5500-mac: emac_w5500_receive(555): read payload failed, len=28526, offset=4708 |
180个成员聚集在这个小组
加入小组453 浏览 1 评论
1450 浏览 1 评论
618浏览 6评论
515浏览 5评论
494浏览 5评论
496浏览 4评论
486浏览 4评论
GMT+8, 2025-2-3 04:06 , Processed in 0.834097 second(s), Total 74, Slave 58 queries .
