ledc 配置如下, led pwm在light-sleep模式下没有PWM输出。
在切换rtc_clk_slow_freq_set(RTC_SLOW_FREQ_8MD256)后,PWM输出才正常,但是电流明显增大。 请问,是否可以在rtc_clk_slow_freq_set(RTC_SLOW_FREQ_32K_XTAL)条件下,进入light-sleep后正常工作? |
// Prepare and then apply the LEDC PWM timer configuration
ledc_timer_config_t ledc_timer = { .speed_mode = LEDC_LOW_SPEED_MODE, .timer_num = LEDC_TIMER_1, .duty_resolution = LEDC_TIMER_9_BIT, .freq_hz = 8000, // Set output frequency at 8 kHz .clk_cfg = LEDC_USE_RTC8M_CLK }; // Prepare and then apply the LEDC PWM channel configuration ledc_channel_config_t ledc_channel = { .speed_mode = LEDC_LOW_SPEED_MODE, .channel = LEDC_CHANNEL_3, .timer_sel = LEDC_TIMER_1, .intr_type = LEDC_INTR_DISABLE, .gpio_num = 5, .duty = 0, // Set duty to 0% .hpoint = 0, .flags.output_invert = 1 }; |
191个成员聚集在这个小组
加入小组470 浏览 1 评论
1646 浏览 2 评论
641浏览 6评论
536浏览 5评论
515浏览 5评论
517浏览 4评论
507浏览 4评论
GMT+8, 2025-2-23 07:19 , Processed in 0.655786 second(s), Total 42, Slave 37 queries .
