就是我在使用esp_http_client_init()函数时,运行时会报错,板子不断reboot,这是什么原因导致的,有什么解决的办法吗?
以下是我调用esp_http_client_init()的相关函数 esp_http_client_config_t config; config.event_handler = ocr_http_event_handler; config.buffer_size = 4 * 1024; config.timeout_ms = 4000; config.url = temp_url.c_str(); Serial.print("config.url = "); Serial.println(config.url); esp_http_client_handle_t client = esp_http_client_init(&config); esp_http_client_set_method(client, HTTP_METHOD_POST); esp_http_client_set_header(client, "Content-Type", "application/x-www-form-urlencoded"); esp_http_client_set_post_field(client, temp_url.c_str(), sizeof(temp_url.c_str())); 以下是报错的内容 Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled. Core 1 register dump: PC : 0x4008d858 PS : 0x00060730 A0 : 0x800d7a48 A1 : 0x3ffb1e00 A2 : 0x0000000f A3 : 0x0000000b A4 : 0x000000ff A5 : 0x0000ff00 A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x00000001 A9 : 0x00000000 A10 : 0x3ffdf50c A11 : 0x3f401614 A12 : 0x000000ff A13 : 0x0000ff00 A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x00000019 EXCCAUSE: 0x0000001c EXCVADDR: 0x0000000f LBEG : 0x4008d879 LEND : 0x4008d889 LCOUNT : 0xfffffffd ELF file SHA256: 0000000000000000 Backtrace: 0x4008d858:0x3ffb1e00 0x400d7a45:0x3ffb1e10 0x400d161b:0x3ffb1e30 0x400d1bb9:0x3ffb1ec0 0x400d537c:0x3ffb1fb0 0x400908de:0x3ffb1fd0 以下是错误的出处 C:Users28032AppDataLocalArduino15packagesesp32toolsxtensa-esp32-elf-gcc1.22.0-97-gc752ad5-5.2.0bin>xtensa-esp32-elf-addr2line -e python.ino.elf 0x4008d858:0x3ffb1e00 0x400d7a45:0x3ffb1e10 0x400d161b:0x3ffb1e30 0x400d1bb9:0x3ffb1ec0 0x400d537c:0x3ffb1fb0 0x400908de:0x3ffb1fd0 /home/mak/e/p/newlib_old/newlib_xtensa-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/strlen.S:46 /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_http_client/esp_http_client.c:335 C:Users28032DocumentsArduinopython/python.ino:163 C:Users28032DocumentsArduinopython/python.ino:283 C:Users28032AppDataLocalArduino15packagesesp32hardwareesp321.0.6coresesp32/main.cpp:30 /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c:355 (discriminator 1) |
125个成员聚集在这个小组
加入小组457浏览 6评论
385浏览 5评论
365浏览 5评论
371浏览 4评论
344浏览 4评论
GMT+8, 2024-9-20 12:27 , Processed in 0.517145 second(s), Total 42, Slave 37 queries .
