尝试跑通ESP HomeKit SDK提供的 Fan 示例工程,但在首次编译时出现错误,执行“idf.py set-target”或“idf.py menuconfig”等命令时报错,截取log中报错部分如下:
Code: Select all CMake Error: Running 'C:/Softwares/Espressif/tools/ninja/1.10.2/ninja.exe' '-C' 'D:/Workspace/eps_homekit/esp-homekit-sdk/examples/fan/build' '-t' 'recompact' failed with: ninja: error: build.ninja:21592: lexing error DEFINES = -D MFI_VER=""4.0-??? Linux ? Windows ????????????? ^ near here CMake Generate step failed. Build files cannot be regenerated correctly. cmake failed with exit code 1 似乎是因为自动生成的 “build/build.ninja” 文件中出现了非法字符, “build/build.ninja” 文件的第21586-21592行内容为: Code: Select all ############################################# # Order-only phony target for __idf_esp_hap_core build cmake_object_order_depends_target___idf_esp_hap_core: phony || cmake_object_order_depends_target___idf_esp_hap_apple_profiles build esp-idf/esp_hap_core/CMakeFiles/__idf_esp_hap_core.dir/src/byte_convert.c.obj: C_COMPILER____idf_esp_hap_core_ D$:/Workspace/eps_homekit/esp-homekit-sdk/components/homekit/esp_hap_core/src/byte_convert.c || cmake_object_order_depends_target___idf_esp_hap_core DEFINES = -D MFI_VER=""4.0-??? Linux ? Windows ????????????? 其中触发错误的21592行内容为: DEFINES = -D MFI_VER=""4.0-??? Linux ? Windows ????????????? 可见在“build/build.ninja” 的 21592 行出现了很多问号,可能是在自动生成时存在编码格式问题,“build/build.ninja” 文件中共有22处相同内容的行,请教如何修复这个问题 |
127个成员聚集在这个小组
加入小组457浏览 6评论
385浏览 5评论
367浏览 5评论
371浏览 4评论
344浏览 4评论
GMT+8, 2024-9-21 18:54 , Processed in 0.834782 second(s), Total 73, Slave 57 queries .
