-- Project sdkconfig file C:/Users/neill/OneDrive/桌面/test2/blink/sdkconfig
Traceback (most recent call last): File "C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/kconfig_new/prepare_kconfig_files.py", line 102, in main() File "C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/kconfig_new/prepare_kconfig_files.py", line 94, in main env.update(json.load(args.env_file)) File "json__init__.py", line 293, in load UnicodeDecodeError: 'cp950' codec can't decode byte 0x8c in position 4121: illegal multibyte sequence Traceback (most recent call last): File "C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/kconfig_new/confgen.py", line 607, in main() File "C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/kconfig_new/confgen.py", line 255, in main env = json.load(args.env_file) File "json__init__.py", line 293, in load UnicodeDecodeError: 'cp950' codec can't decode byte 0x8c in position 4121: illegal multibyte sequence CMake Error at C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/cmake/kconfig.cmake:176 (message): Failed to run confgen.py (c:/Espressif/python_env/idf5.0_py3.8_env/Scripts/python.exe;C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/kconfig_new/confgen.py;--list-separator=semicolon;--kconfig;C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/Kconfig;--sdkconfig-rename;C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/sdkconfig.rename;--config;C:/Users/neill/OneDrive/桌面/test2/blink/sdkconfig;--env-file;C:/Users/neill/OneDrive/桌面/test2/blink/build/config.env). Error 1 Call Stack (most recent call first): C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/cmake/build.cmake:590 (__kconfig_generate_config) C:/Espressif/frameworks/esp-idf-v5.0/esp-idf/tools/cmake/project.cmake:440 (idf_build_process) CMakeLists.txt:6 (project) -- Configuring incomplete, errors occurred! See also "C:/Users/neill/OneDrive/桌面/test2/blink/build/CMakeFiles/CMakeOutput.log". 5.0新版本ESP_IDF 全部都顯示正確安裝後,編譯例程後,會顯示 UnicodeDecodeError: 'cp950' codec can't decode byte 0x8c in position 4121: illegal multibyte sequence 在其他電腦的4.4.3版本下沒有這個問題 有人知道解答嗎? |
179个成员聚集在这个小组
加入小组439 浏览 1 评论
1396 浏览 1 评论
608浏览 6评论
505浏览 5评论
487浏览 5评论
489浏览 4评论
472浏览 4评论
GMT+8, 2025-1-23 11:30 , Processed in 0.603360 second(s), Total 41, Slave 36 queries .
