ESP-IDF v4.4.2
芯片是 ESP32-D0WDQ6 我正在尝试读取核心转储信息。 首先,我正在使用 esptool 读取 Flash 代码: esptool.py --port /dev/ttyUSB0 read_flash 0x3ec000 0xE000 ./core.bin 然后我尝试使用以下方法提取信息: 代码: espcoredump.py info_corefile --core ./core.bin --core-format raw build/httpsOTA_S_FE.elf 但脚本给我以下错误: 代码: espcoredump.py v0.4-dev =============================================================== ==================== ESP32 CORE DUMP START ==================== Traceback (most recent call last): File "/home/praveen/opt/esp/idf-4.4.2/esp-idf/components/espcoredump/espcoredump.py", line 350, in temp_core_files = info_corefile() File "/home/praveen/opt/esp/idf-4.4.2/esp-idf/components/espcoredump/espcoredump.py", line 170, in info_corefile gdb = EspGDB(gdb_tool, [rom_sym_cmd], core_elf_path, args.prog, timeout_sec=args.gdb_timeout_sec) File "/home/praveen/opt/esp/idf-4.4.2/esp-idf/components/espcoredump/corefile/gdb.py", line 45, in __init__ self._gdbmi_run_cmd_get_responses(cmd='-data-list-register-values x pc', File "/home/praveen/opt/esp/idf-4.4.2/esp-idf/components/espcoredump/corefile/gdb.py", line 63, in _gdbmi_run_cmd_get_responses more_responses = self.p.get_gdb_response(timeout_sec=0, raise_error_on_timeout=False) File "/home/praveen/.espressif/python_env/idf4.4_py3.10_env/lib/python3.10/site-packages/pygdbmi/gdbcontroller.py", line 269, in get_gdb_response self.verify_valid_gdb_subprocess() File "/home/praveen/.espressif/python_env/idf4.4_py3.10_env/lib/python3.10/site-packages/pygdbmi/gdbcontroller.py", line 175, in verify_valid_gdb_subprocess raise NoGdbProcessError( pygdbmi.gdbcontroller.NoGdbProcessError: gdb process has already finished with return code: 127 我的最终目标是将此分区信息发送到我的服务器并在服务器上进行调试。我首先希望能够在我的主机上进行调试,以了解我如何在我的服务器上实现。 |
180个成员聚集在这个小组
加入小组448 浏览 1 评论
1443 浏览 1 评论
615浏览 6评论
511浏览 5评论
489浏览 5评论
492浏览 4评论
478浏览 4评论
GMT+8, 2025-1-31 22:45 , Processed in 0.573787 second(s), Total 40, Slave 35 queries .
