我已经将我的代码从 ESP-IDF 4.3 更新到 5.0,其中一个变化是通用定时器,我正在尝试在自定义项目上使用定时器,它会构建并闪烁,但是当我打开时我在显示器上收到这个错误。
代码:全选 0x4012a555: timer_ll_set_clock_prescale at /home/vendpago/esp/esp-idf/components/hal/esp32/include/hal/timer_ll.h:68 (inlined by) gptimer_select_periph_clock at /home/vendpago/esp/esp-idf/components/driver/gptimer.c:480 0x4012a8ab: gptimer_new_timer at /home/vendpago/esp/esp-idf/components/driver/gptimer.c:184 (discriminator 2) 0x400d9229: init_timer0 at /home/vendpago/esp/PayBluEsp/main/Timers.c:215 0x400d93e2: app_main_timer at /home/vendpago/esp/PayBluEsp/main/Timers.c:272 (discriminator 13) 这是 init_timer0 的代码: 代码:全选 void init_timer0(){ ESP_LOGI(TAGtimer, "Create timer handle"); gptimer_handle_t gptimer0 = NULL; gptimer_config_t timer_config = { .clk_src = GPTIMER_CLK_SRC_APB, .direction = GPTIMER_COUNT_UP, .resolution_hz = 1000, // 1kHz, 1 tick=1ms }; ESP_ERROR_CHECK(gptimer_new_timer(&timer_config, &gptimer0)); gptimer_event_callbacks_t cbs = { .on_alarm = timer_group0_isr, // register user callback }; ESP_ERROR_CHECK(gptimer_register_event_callbacks(gptimer0, &cbs, timer_queue)); ESP_ERROR_CHECK(gptimer_enable(gptimer0)); gptimer_alarm_config_t alarm_config = { .reload_count = 0, // counter will reload with 0 on alarm event .alarm_count = TIMER_INTERVAL0_SEC, // period = 1249ms @resolution 1kHz .flags.auto_reload_on_alarm = true, // enable auto-reload }; ESP_ERROR_CHECK(gptimer_set_alarm_action(gptimer0, &alarm_config)); ESP_ERROR_CHECK(gptimer_start(gptimer0)); } 我尝试使用 GPTIMER 中的示例代码,它完美地工作。 |
198个成员聚集在这个小组
加入小组482 浏览 1 评论
1780 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
383浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
177浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
223浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
575浏览 2评论
268浏览 2评论
GMT+8, 2025-3-6 03:05 , Processed in 1.105114 second(s), Total 42, Slave 37 queries .
