我在 Windows 机器上使用 ESP-Prog。
我在面包板上使用连接到 HUZZA32 Feather 的 ESP-Prog。 信号:ESP-PROG -> HUZZA32 MTCK:4 - MTCK -> 13 - MTCK MTDI:8 - TDI -> 12 - MTDI MTDO:6 - TDO -> 15 - MTDO MTMS:2 - TMS -> 14 - MTMS 3V: 1 - VJTAG -> 3.3V GND:3 - GND -> GND 我修改了 JTAG 驱动程序以使用 WinUSB。 我正在使用在 github https://github.com/espressif/openocd-es ... 2-20221026上找到的 OpenOCD ESP32 v0.11.0 版本。 以下是我用来刷机的步骤: 代码:全选 cd C:openocd-esp32-win32-0.11.0-esp32-20220706openocd-esp32in openocd.exe -f ..shareopenocdscriptsoardesp32-wrover-kit-3.3v.cfg -c "program_esp file.bin 0x10000 verify exit" 这是我得到的回应。 代码:全选 C:openocd-esp32-win32-0.11.0-esp32-20220706openocd-esp32in>openocd.exe -f ..shareopenocdscriptsoardesp32-wrover-kit-3.3v.cfg -c "program_esp file.bin 0x10000 verify exit" Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling" Info : clock speed 20000 kHz Error: JTAG scan chain interrogation failed: all ones Error: Check JTAG interface, timings, target power, etc. Error: Trying to use configured scan chain anyway... Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01 Warn : Bypassing JTAG setup events due to errors Error: Unexpected OCD_ID = ffffffff Warn : target esp32.cpu0 examination failed Error: Unexpected OCD_ID = ffffffff Warn : target esp32.cpu1 examination failed Info : starting gdb server for esp32.cpu0 on 3333 Info : Listening on port 3333 for gdb connections Error: JTAG scan chain interrogation failed: all ones Error: Check JTAG interface, timings, target power, etc. Error: Trying to use configured scan chain anyway... Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01 Warn : Bypassing JTAG setup events due to errors Error: Unexpected OCD_ID = ffffffff Error: Unexpected OCD_ID = ffffffff Info : [esp32.cpu0] requesting target halt and executing a soft reset Error: Target not examined yet Info : [esp32.cpu1] requesting target halt and executing a soft reset Error: Target not examined yet Error: Unexpected OCD_ID = ffffffff ** Unable to reset target ** shutdown command invoked 我已经以各种方式尝试过很多次了。有一次它几乎成功了,但我从未成功进行过 JTAG 扫描或文件上传。 这里有什么问题? |
194个成员聚集在这个小组
加入小组478 浏览 1 评论
1729 浏览 2 评论
541浏览 5评论
520浏览 4评论
509浏览 4评论
为blufi_device设置自定义名称,但是无法修改,为什么?
378浏览 4评论
为何ESP32S3 BLE把对端地址加入白名单后苹果手机依然能扫描到呢?
503浏览 3评论
GMT+8, 2025-3-2 03:58 , Processed in 0.925001 second(s), Total 74, Slave 58 queries .
