我正在尝试采用下面的草图与我的 WeMos D1 mini 和众所周知的旋转编码器 KY-040 一起使用,但由于某种原因它不起作用,但相同的草图在 Arduino Uno 上运行良好(与不同的引脚分配)。
有人能告诉我草图有什么问题吗? 谢谢你! 代码:全选const int PinA = 14; // Used for generating interrupts using CLK signal const int PinB = 12; // Used for reading DT signal const int PinSW = 13; // Used for the push button switch int lCnt = 0; // Keep track of last rotary value volatile int vPos = 0; // Updated by the ISR (Interrupt Service Routine) void isr_event () { static unsigned long lIsrTmr = 0; // Last Interrupt time unsigned long IsrTmr = millis(); // Interrupt time // If interrupts come faster than 5ms, assume it's a bounce and ignore if (IsrTmr - lIsrTmr > 5) { if (digitalRead(PinB) == LOW) { vPos++ ; // Could be +5 or +10 } else { vPos-- ; // Could be -5 or -10 } // Restrict value from 0 to +100 vPos = min(10, max(0, vPos)); // Keep track of when we were here last (no more than every 5ms) lIsrTmr = IsrTmr; } } void setup() { Serial.begin(9600); // Rotary pulses are INPUTs pinMode(PinA, INPUT); pinMode(PinB, INPUT); pinMode(PinSW, INPUT_PULLUP); // Switch is floating so use the in-built PULLUP so we don't need a resistor attachInterrupt(digitalPinToInterrupt(PinA), isr_event, LOW); // Attach the routine to service the interrupts Serial.println(F("Starting...")); // Ready to go! } void loop() { // Is someone pressing the rotary switch? if ((!digitalRead(PinSW))) { vPos = 0; while (!digitalRead(PinSW)) delay(10); } // If the current rotary switch position has changed then update everything if (vPos != lCnt) { // Write out to serial monitor the value and direction Serial.println(vPos); // Keep track of this new value lCnt = vPos ; } } |
184个成员聚集在这个小组
加入小组459 浏览 1 评论
1528 浏览 2 评论
629浏览 6评论
520浏览 5评论
500浏览 5评论
503浏览 4评论
493浏览 4评论
GMT+8, 2025-2-12 04:35 , Processed in 0.605118 second(s), Total 47, Slave 38 queries .
