大家好,
我正在尝试连接 Nest_api ( ) 除了我遇到的棘手的安全问题外,我什至无法从 我尝试过的 API 中获取数据有几件事,我总是会收到“重定向”错误。这意味着我没有访问权限。 我开始相信我在 HTTPS 请求方面遇到了一些问题。有人遇到过类似的问题吗? 你可以在这里查看我的代码: 我尝试访问服务器的部分是最后一段代码。 代码:全选Basic Infos The goal is to let a switch respond on the data received from my nest Thermostad. I'm using the Nest_API to get the result Hardware Hardware: ESP8266 Description I'm trying to access the Nest API without any success. I always get some kind of redirection error. Or I get the 307 error code (redirection) or an 400. With the first one, there's no redirection location. What do i do wrong? Is it possible that the library doesn't support HTPPS? Is there a solution for it? Settings in IDE Module: Generic ESP8266 Module Sketch #include #include #include #include #define USE_SERIAL Serial String accessurl = "https://api.home.nest.com/oauth2/access_token"; MDNSResponder mdns; // My Network cred. const char* ssid = "Blanked out"; const char* password = "Blanked out"; int gpio13Led = 13; int gpio12Relay = 12; void setup(void){ // preparing GPIOs pinMode(gpio13Led, OUTPUT); digitalWrite(gpio13Led, HIGH); pinMode(gpio12Relay, OUTPUT); digitalWrite(gpio12Relay, HIGH); Serial.begin(115200); delay(5000); WiFi.begin(ssid, password); Serial.println(""); // Wait for connection while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.print("Connected to "); Serial.println(ssid); Serial.print("IP address: "); Serial.println(WiFi.localIP()); if (mdns.begin("esp8266", WiFi.localIP())) { Serial.println("MDNS responder started"); } } void loop(void){ Serial.println("Wifi Up - Test Start!"); delay(10000); if((WiFi.status() != WL_CONNECTED)) { Serial.println("wifi down"); return; } HTTPClient http; //Here I gave the footprint along with the url. But I'm not sure if it works. http.begin("https://developer-api.nest.com/", "87:CB:F2:E6:44:C0:AA:F2:4C:28:B2:97:85:70:18:92:45:1B:A4:57"); //http.addHeader("Cache-Control", "no-cache", true, true); //http.addHeader("Postman-Token", "419da1fa-6070-3338-c215-8be740891136", true, true); http.addHeader("Authorization", "Bearer c.blanked out", true, true); http.addHeader("Host", "developer-api.nest.com", true, true); http.addHeader("Content-Type", "application/json", false, true); int httpCode = http.GET(); Serial.println("request sent: n"); Serial.println(httpCode); //Doesn't seem to work? I never see any outprint. if (httpCode == HTTP_CODE_OK) { String payload = http.getString(); Serial.printf("[HTTP] GET response: %s", payload.c_str()); } else { String payload = http.getString(); String loc = http.header("Location"); Serial.printf("[HTTP] GE returned %d. kapot, error: %s; response: %s, new location: %sn", httpCode, http.errorToString(httpCode).c_str(), payload.c_str(), loc.c_str()); } http.end(); } |
127个成员聚集在这个小组
加入小组457浏览 6评论
385浏览 5评论
366浏览 5评论
371浏览 4评论
344浏览 4评论
GMT+8, 2024-9-21 08:10 , Processed in 0.821591 second(s), Total 75, Slave 59 queries .
