我的 IDE 无法连接模块。我在这些事情上是新手,还在学习,我以前一直在使用一些 Arduino 电子产品,但从来没有遇到过这样的问题。我认为一切都设置正确:
但是,当我尝试编译代码时,我首先收到警告,然后在上传时出现以下错误: 代码:全选Arduino: 1.8.10 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200" Executable segment sizes: IROM : 235644 - code in flash (default or ICACHE_FLASH_ATTR) IRAM : 26908 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...) DATA : 1264 ) - initialized variables (global, static) in RAM/HEAP RODATA : 752 ) / 81920 - constants (global, static) in RAM/HEAP BSS : 24976 ) - zeroed variables (global, static) in RAM/HEAP Sketch uses 264568 bytes (27%) of program storage space. Maximum is 958448 bytes. Global variables use 26992 bytes (32%) of dynamic memory, leaving 54928 bytes for local variables. Maximum is 81920 bytes. esptool.py v2.8 Serial port COM3 Traceback (most recent call last): File "C:Users38971AppDataLocalArduino15packagesesp8266hardwareesp82662.6.3/tools/upload.py", line 65, in esptool.main(cmdline) File "C:/Users/38971/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptoolesptool.py", line 2889, in main esp = chip_class(each_port, initial_baud, args.trace) File "C:/Users/38971/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptoolesptool.py", line 237, in __init__ self._port = serial.serial_for_url(port) File "C:/Users/38971/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/pyserialserial__init__.py", line 88, in serial_for_url instance.open() File "C:/Users/38971/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/pyserialserialserialwin32.py", line 62, in open raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError())) serial.serialutil.SerialException: could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5) serial.serialutil.SerialException: could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5) This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences. 你们能否建议我对以下问题有哪些选择,或者告诉我在哪里可以找到解决方案? |
198个成员聚集在这个小组
加入小组486 浏览 1 评论
1804 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
388浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
179浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
225浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
578浏览 2评论
271浏览 2评论
GMT+8, 2025-3-9 07:43 , Processed in 0.899083 second(s), Total 72, Slave 56 queries .
