我尝试将具有 ESP8266 内核的 ESP-wroom-02 配置为 SPI 从设备。但是除了威廉希尔官方网站
参考 ESP8266 之外,没有找到太多关于 SPI 配置的信息。该项目有一个 arduino nano iot 33 (samd21g18 arm-m0) 作为与 Slave ESP8266 通信的主机。
我用逻辑分析仪检查了主机发送数据和时钟,但从机没有响应。我还测试了使用 arduino uno 作为从站,并与 arduino iot SPI Master 一起工作。 引脚设置: - 在 ESP 上:IO14->SCK、IO12->MISO、IO13->MOSI、IO15->CS - 在 Arduino 上:D12->MISO、D13->SCK、D11->MOSI、D10->CS 从代码: 主例程 代码:全选#include "hspiESP8266.h" #include using namespace std; #define MISO 12 #define MOSI 13 extern uint8_t bdata[LENGTH]; char c = 'c'; bdata[0] = (uint8_t)c; void setup() { Serial.begin(115200); pinMode(MISO, OUTPUT); pinMode(MOSI, INPUT); HSPISlave SPIS; attachInterrupt(digitalPinToInterrupt(SYNC), sync_isr, FALLING); SPIS.begin(); } void loop() { delay(100); Serial.println((data[0] << 16)); } 头文件 代码:全选#include "hspiESP8266.h" volatile bool data_ready = false; // set by HSPI interrupt handler when data is received volatile bool new_readings = false; // set by sync pin interrupt when readings are extracted from raw data CACHE_RAM_ATTR sync_isr(); void ICACHE_RAM_ATTR _hspi_slave_isr_handler(void *); uint8_t bdata[LENGTH]; uint8_t* read_hspi(){ return bdata; } void ICACHE_RAM_ATTR _hspi_slave_isr_handler(void *) { uint32_t istatus = SPIIR; if(istatus & (1 << SPII1)) { //SPI1 ISR uint32_t status = SPI1S; SPI1S &= ~(0x3E0); //disable interrupts SPI1S |= SPISSRES; //reset SPI1S &= ~(0x1F); //clear interrupts SPI1S |= (0x3E0); //enable interrupts if(status & SPISWBIS) { uint8_t *p = bdata; for(int i = 0; i < LENGTH / 4; i++) { uint32_t dword = SPI1W(i); *p++ = dword; *p++ = dword >> 8; *p++ = dword >> 16; *p++ = dword >> 24; } data_ready = true; } } else if(istatus & (1 << SPII0)) { //SPI0 ISR SPI0S &= ~(0x3ff);//clear SPI ISR } else if(istatus & (1 << SPII2)) {} //I2S ISR } void ICACHE_RAM_ATTR sync_isr() { // Sync pin interrupt on falling edge SPI1S |= SPISSRES; // Reset HSPI slave SPI1S &= ~SPISSRES; SPI1CMD = SPICMDUSR; // Start HSPI slave static bool glitch = false; if(data_ready) { // If a data has been received by the HSPI data_ready = false; if( glitch) { // reject samples that have been shifted right by noise on the clock line? glitch = false; // sample accepted new_readings = true; // new raw readings ready } else glitch = true; // only reject one sample } } //contructor HSPISlave::HSPISlave(){ } void HSPISlave::begin(){ pinMode(SCK, SPECIAL); // Both inputs in slave mode pinMode(MOSI, SPECIAL); SPI1C = 0; // SPI_CTRL_REG MSB first, single bit data mode. SPI1S = SPISE | SPISBE | SPISCD | 0x3E0;// SPI_SLAVE_REG, set slave mode, WR/RD BUF enable, CMD define, enable interrupts SPI1U = SPIUSSE; // SPI_USER_REG. SPI_CK_I_EDGE SPI1CLK = 0; // SPI_CLOCK_REG SPI1U1 = 7 << SPILADDR; // SPI_USER1_REG, set address LENGTH to 8 bits SPI1U2 = 7 << SPILCOMMAND; // SPI_USER2_REG, set command LENGTH to 8 bits SPI1S1 = (LENGTH * 8 - 1) << SPIS1LBUF; // SPI_SLAVE1_REG, SPI_SLV_BUF_BITLEN = 12 bytes SPI1S3 = 0xF1F200F3; // SPI_SLAVE3_REG,, Define command 0 to be write buffer, others something doesn't match SPI1P = 1 << 19; // SPI_PIN_REG, Clock idle high, seems to cause contension on the clock pin if set to idle low. ETS_SPI_INTR_ATTACH(_hspi_slave_isr_handler, 0); ETS_SPI_INTR_ENABLE(); } void HSPISlave::end(){ SPI1S |= SPISSRES; SPI1CMD = 0; pinMode(SCK, INPUT); // Return to inputs to avoid glicthing the PZEM-021 during reset pinMode(MOSI, INPUT); } void HSPISlave::INTreset(){ SPI1S &= ~(0x3E0); //disable interrupts SPI1S |= SPISSRES; //reset SPI1S &= ~(0x1F); //clear interrupts SPI1S |= (0x3E0); //enable interrupts } void HSPISlave::reset(){ SPI1S |= SPISSRES; // Reset HSPI slave SPI1S &= ~SPISSRES; SPI1CMD = SPICMDUSR; // Start HSPI slave } |
198个成员聚集在这个小组
加入小组483 浏览 1 评论
1786 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
385浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
177浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
223浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
575浏览 2评论
268浏览 2评论
GMT+8, 2025-3-7 03:22 , Processed in 0.707817 second(s), Total 42, Slave 37 queries .
