芯片:ESP32-WROVER-B
IDF版本:release/v4.3 开发环境:Windows10 各位好,我遇到spiffs初始化失败的问题,但我感觉我给的config应该没啥问题?
整段代码如下: Code: Select all void storageInit() { static const char* tag = "storageInit"; ESP_LOGD(tag, "storageInit() called"); esp_vfs_spiffs_conf_t conf = { .base_path = "/abcdefghi_files", .partition_label = NULL, .max_files = 4, .format_if_mount_failed = false}; // Use settings defined above to initialize and mount SPIFFS filesystem. // Note: esp_vfs_spiffs_register is an all-in-one convenience function. esp_err_t ret = esp_vfs_spiffs_register(&conf); if (ret != ESP_OK) { if (ret == ESP_FAIL) { ESP_LOGE(tag, "Failed to mount or format filesystem"); throw std::runtime_error("fail to mount"); } else if (ret == ESP_ERR_NOT_FOUND) { ESP_LOGE(tag, "Failed to find SPIFFS partition"); throw std::runtime_error("no partition"); } else { ESP_LOGE(tag, "Failed to initialize SPIFFS (%s)", esp_err_to_name(ret)); throw std::runtime_error("fail to init"); } return; } size_t total = 0, used = 0; ret = esp_spiffs_info(NULL, &total, &used); if (ret != ESP_OK) { ESP_LOGE(tag, "Failed to get SPIFFS partition information (%s)", esp_err_to_name(ret)); } else { ESP_LOGD(tag, "Partition size: total: %d, used: %d", total, used); } } 然后串口打印如下
请问这个ESP_ERR_INVALID_ARG是怎么导致的? 我的sdkconfig里spiffs相关的内容如下
partition如下:
storage里面只有一个文件,文件名长度24字节,文件大小46字节 |
116个成员聚集在这个小组
加入小组419浏览 6评论
352浏览 5评论
334浏览 5评论
337浏览 4评论
317浏览 4评论
GMT+8, 2024-8-24 13:16 , Processed in 0.720064 second(s), Total 75, Slave 59 queries .
