SDK idf4.2.1
ubuntu20.04 编译报错如下 /root/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: balance_car.elf section `.iram0.text' will not fit in region `iram0_0_seg' /root/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: IRAM0 segment data does not fit. /root/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: region `iram0_0_seg' overflowed by 1040 bytes collect2: error: ld returned 1 exit status make[3]: *** [CMakeFiles/balance_car.elf.dir/build.make:403: balance_car.elf] Error 1 make[2]: *** [CMakeFiles/Makefile2:2053: CMakeFiles/balance_car.elf.dir/all] Error 2 make[1]: *** [CMakeFiles/Makefile2:4315: esp-idf/esptool_py/CMakeFiles/app-flash.dir/rule] Error 2 make: *** [Makefile:1308: app-flash] Error 2 make failed with exit code 2 |
192个成员聚集在这个小组
加入小组470 浏览 1 评论
1648 浏览 2 评论
642浏览 6评论
536浏览 5评论
515浏览 5评论
517浏览 4评论
507浏览 4评论
GMT+8, 2025-2-23 15:30 , Processed in 0.676183 second(s), Total 41, Slave 36 queries .
