Code: Select all
-- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: D:/ESP/.espressif/tools/xtensa-esp32-elf/esp-2021r1-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: D:/ESP/.espressif/tools/xtensa-esp32-elf/esp-2021r1-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32 -- Project sdkconfig file D:/ESP/esp-idf/examples/bluetooth/bluedroid/ble/ble_ancs/sdkconfig Loading defaults file D:/ESP/esp-idf/examples/bluetooth/bluedroid/ble/ble_ancs/sdkconfig.defaults... Loading defaults file D:/ESP/esp-idf/examples/bluetooth/bluedroid/ble/ble_ancs/sdkconfig.defaults.esp32... CMake Error at ../../../../../tools/cmake/component.cmake:306 (message): Include directory 'D:/ESP/esp-idf/components/mbedtls/mbedtls/include' is not a directory. Call Stack (most recent call first): ../../../../../tools/cmake/component.cmake:478 (__component_add_include_dirs) ../../../../../components/mbedtls/CMakeLists.txt:10 (idf_component_register) -- Configuring incomplete, errors occurred! See also "D:/ESP/esp-idf/examples/bluetooth/bluedroid/ble/ble_ancs/build/CMakeFiles/CMakeOutput.log". cmake failed with exit code 1 |
191个成员聚集在这个小组
加入小组470 浏览 1 评论
1640 浏览 2 评论
641浏览 6评论
536浏览 5评论
514浏览 5评论
517浏览 4评论
506浏览 4评论
GMT+8, 2025-2-22 16:52 , Processed in 0.534083 second(s), Total 40, Slave 35 queries .
