开始我发现我购买的ESP32-S2-WROOM模块无法正常烧录
COM8 failed to connect: Failed to connect to Espressif device: Invalid head of packet (0x65) 使用PIO或者ESP tool都是如下结果。 在拉低IO0进入下载模式后,板子上的TX灯一直亮着,使用串口助手,发现当ESP32-S2进入下载模式后 一直以极快的速度重复发送以下数据: [20:52:51.462]收←◆[0;32mI (78) boot: ESP-IDF v4.2-dev-2044-gdd3c032 2nd stage bootloader[0m [0;32mI (78) boot: compile time 04:59:46[0m [0;32mI (79) boot: chip revision: 0[0m [0;31mE (81) boot_comm: mismatch chip ID, expected 2, found 0[0m ESP-ROM:esp32s2-rc4-20191025 Build:Oct 25 2019 rst:0x3 (RTC_SW_SYS_RST),boot:0x4 (SPI_FLASH_BOOT) Saved PC:0x40055134 SPIWP:0xee mode:DIO, clock div:1 load:0x3ffe8100,len:4 load:0x3ffe8104,len:6536 load:0x40050000,len:6292 load:0x40054000,len:8460 entry 0x40050314 [20:52:51.563]收←◆[0;32mI (78) boot: ESP-IDF v4.2-dev-2044-gdd3c032 2nd stage bootloader[0m [0;32mI (78) boot: compile time 04:59:46[0m [0;32mI (79) boot: chip revision: 0[0m [0;31mE (81) boot_comm: mismatch chip ID, expected 2, found 0[0m ESP-ROM:esp32s2-rc4-20191025 Build:Oct 25 2019 rst:0x3 (RTC_SW_SYS_RST),boot:0x4 (SPI_FLASH_BOOT) Saved PC:0x40055134 SPIWP:0xee mode:DIO, clock div:1 load:0x3ffe8100,len:4 load:0x3ffe8104,len:6536 load:0x40050000,len:6292 load:0x40054000,len:8460 entry 0x40050314 该芯片之前没有烧录过程序。 不知道有没有大佬知道该怎么解决? |
180个成员聚集在这个小组
加入小组453 浏览 1 评论
1452 浏览 1 评论
618浏览 6评论
515浏览 5评论
495浏览 5评论
496浏览 4评论
486浏览 4评论
GMT+8, 2025-2-4 02:57 , Processed in 0.629919 second(s), Total 40, Slave 35 queries .
