扫一扫,分享给好友
FAILED: CMakeFiles/flash
cmd.exe /C "cd /D E:espesp_idfcomponentsesptool_py && E:esp.espressiftoolscmake3.16.4bincmake.exe -D IDF_PATH="E:/esp/esp_idf" -D SERIAL_TOOL="E:/esp/.espressif/python_env/idf4.3_py3.8_env/Scripts/python.exe E:/esp/esp_idf/components/esptool_py/esptool/esptool.py --chip esp32c3" -D SERIAL_TOOL_ARGS="--before=default_reset --after=hard_reset write_flash @flash_args" -D WORKING_DIRECTORY="E:/esp/esp_idf/examples/wifi/fast_scan/build" -P E:/esp/esp_idf/components/esptool_py/run_serial_tool.cmake" ninja: build stopped: subcommand failed. ninja failed with exit code 1 |
198个成员聚集在这个小组
加入小组483 浏览 1 评论
1786 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
385浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
177浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
223浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
575浏览 2评论
268浏览 2评论
GMT+8, 2025-3-7 02:32 , Processed in 0.688632 second(s), Total 41, Slave 36 queries .
