A fatal error occurred: Failed to connect to ESP32-C3: Invalid head of packet (0x6C)
CMake Error at run_serial_tool.cmake:50 (message): E:/esp/.espressif/python_env/idf4.3_py3.8_env/Scripts/python.exe E:/esp/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32c3 failed FAILED: CMakeFiles/flash cmd.exe /C "cd /D E:espesp-idfcomponentsesptool_py && E:esp.espressiftoolscmake3.16.4bincmake.exe -D IDF_PATH="E:/esp/esp-idf" -D SERIAL_TOOL="E:/esp/.espressif/python_env/idf4.3_py3.8_env/Scripts/python.exe E:/esp/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32c3" -D SERIAL_TOOL_ARGS="--before=default_reset --after=hard_reset write_flash @flash_args" -D WORKING_DIRECTORY="E:/esp/esp-idf/esp-aws-iot/examples/motor_smart_config_aws/build" -P E:/esp/esp-idf/components/esptool_py/run_serial_tool.cmake" ninja: build stopped: subcommand failed. ninja failed with exit code 1 |
169个成员聚集在这个小组
加入小组321 浏览 0 评论
1178 浏览 1 评论
586浏览 6评论
483浏览 5评论
468浏览 5评论
467浏览 4评论
442浏览 4评论
GMT+8, 2024-12-27 00:46 , Processed in 0.670780 second(s), Total 43, Slave 38 queries .
