代码是从https://github.com/espressif/esp-iot-solution/下载的,不管是使用git下载,还是download压缩包,代码都是一样的。
下面是几个下载过程和编绎的图片。 我编绎的是工程“usb_camera_sd_card”. 使用命令idf.py set-target esp32s2提示以下错误: Directory 'i:esp32-s2-c3esp-devesp-dev-kits-masteraaesp-iot-solutionexamplesusbhostusb_camera_sd_cardbuild' doesn't seem to be a CMake build directory. Refusing to automatically delete files in this directory. Delete the directory manually to 'clean' it. 使用命令idf.py build提示以下错误: -- Building ESP-IDF components for target esp32 CMake Error at I:/ESP32/esp-idf-v4.3/tools/cmake/build.cmake:189 (message): Failed to resolve component 'usb'. Call Stack (most recent call first): I:/ESP32/esp-idf-v4.3/tools/cmake/build.cmake:215 (__build_resolve_and_add_req) I:/ESP32/esp-idf-v4.3/tools/cmake/build.cmake:435 (__build_expand_requirements) I:/ESP32/esp-idf-v4.3/tools/cmake/project.cmake:396 (idf_build_process) CMakeLists.txt:17 (project) -- Configuring incomplete, errors occurred! See also "I:/ESP32-S2-C3/ESP-dev/esp-dev-kits-master/aa/esp-iot-solution/examples/usb/host/usb_camera_sd_card/build/CMakeFiles/CMakeOutput.log". cmake failed with exit code 1 我使用的环境是IDF4.3,编绎4.3自带的教程是没有问题的,有大神指点一下问题所在吗? 切换到usb/add_usb_solutions后使用命令:git submodule update --init --recursive的方法我试了,错误是一样的。 |
168个成员聚集在这个小组
加入小组313 浏览 0 评论
1170 浏览 1 评论
585浏览 6评论
483浏览 5评论
468浏览 5评论
467浏览 4评论
442浏览 4评论
GMT+8, 2024-12-26 11:52 , Processed in 0.677821 second(s), Total 43, Slave 38 queries .
