MASTER版本。见红色字体,疑问:bulk transfer附加0长度报文应该只针对out方向吧?我理解应该是!is_in ...
static inline void _buffer_fill_bulk(dma_buffer_block_t *buffer, usb_transfer_t *transfer, bool is_in) { if (is_in) { usbh_hal_xfer_desc_fill(buffer->xfer_desc_list, 0, transfer->data_buffer, transfer->num_bytes, USBH_HAL_XFER_DESC_FLAG_IN | USBH_HAL_XFER_DESC_FLAG_HOC); } else if (transfer->flags & USB_TRANSFER_FLAG_ZERO_PACK) { //We need to add an extra zero length packet, so two descriptors are used usbh_hal_xfer_desc_fill(buffer->xfer_desc_list, 0, transfer->data_buffer, transfer->num_bytes, 0); usbh_hal_xfer_desc_fill(buffer->xfer_desc_list, 1, NULL, 0, USBH_HAL_XFER_DESC_FLAG_HOC); } else { usbh_hal_xfer_desc_fill(buffer->xfer_desc_list, 0, transfer->data_buffer, transfer->num_bytes, USBH_HAL_XFER_DESC_FLAG_HOC); } //Update buffer flags buffer->flags.bulk.zero_len_packet = (is_in && (transfer->flags & USB_TRANSFER_FLAG_ZERO_PACK)) ? 1 : 0; } |
192个成员聚集在这个小组
加入小组472 浏览 1 评论
1655 浏览 2 评论
647浏览 6评论
536浏览 5评论
516浏览 5评论
517浏览 4评论
507浏览 4评论
GMT+8, 2025-2-25 02:15 , Processed in 0.780424 second(s), Total 75, Slave 59 queries .
