打印:
I (182) opi psram: vendor id : 0x0d (AP) I (182) opi psram: dev id : 0x02 (generation 3) I (182) opi psram: density : 0x03 (64 Mbit) I (186) opi psram: good-die : 0x01 (Pass) I (191) opi psram: Latency : 0x01 (Fixed) I (196) opi psram: VCC : 0x01 (3V) I (200) opi psram: SRF : 0x01 (Fast Refresh) I (206) opi psram: BurstType : 0x01 (Hybrid Wrap) I (211) opi psram: BurstLen : 0x01 (32 Byte) I (216) opi psram: Readlatency : 0x02 (10 cycles@Fixed) I (222) opi psram: DriveStrength: 0x00 (1/1) I (227) spiram: Found 64MBit SPI RAM device I (232) spiram: SPI RAM mode: sram 40m I (236) spiram: PSRAM initialized, cache is in normal (1-core) mode. I (243) cpu_start: Pro cpu up. I (247) cpu_start: Starting app cpu, entry point is 0x40375278 0x40375278: call_start_cpu1 at /home/xxxxx/esp/esp-idf/components/esp_system/port/cpu_start.c:156 I (0) cpu_start: App cpu up. I (985) spiram: SPI SRAM memory test OK W (985) rtcinit: calibration efuse version does not match, set default version: 0 |
172个成员聚集在这个小组
加入小组432 浏览 1 评论
1300 浏览 1 评论
599浏览 6评论
498浏览 5评论
481浏览 5评论
481浏览 4评论
464浏览 4评论
GMT+8, 2025-1-13 19:07 , Processed in 0.576628 second(s), Total 42, Slave 36 queries .
