开发环境:VSCode + Platformio + Arduino
硬件平台:ESP32C3 ESP-IDF版本:V4.1.2 Platformio PACKAGES: - tool-esptoolpy 1.30100.210531 (3.1.0) - toolchain-riscv-esp 1.80400.0 (8.4.0) 由于项目要求,以ESP32C3为平台的自研电路板,现在碰见一个比较棘手的问题无法解决。当加载BLE时,烧录后就不断重启,如果不加载BLE,只进行控制,如PWM,ADc,GPIO之类的都是ok的。网上找寻了很多信息,依然没解决问题,请高手指点。 BLE的初始化函数:(只执行到这里,就出异常) BLEDevice::init(DEVICE_NAME); 不断重启的log信息: ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0xf (BROWNOUT_RST),boot:0xf (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd6100,len:0x12f4 load:0x403ce000,len:0x93c load:0x403d0000,len:0x292c SHA-256 comparison failed: Calculated: 8d996f0c10c713e532f0d62ceb5bd044db8011bcaef3163574bcc3fc4768f05d Expected: e9d7702986eabdb730063e52592f19701feea7da0d2207d674ef148b8cdb3216 Attempting to boot anyway... entry 0x403ce000 I (49) boot: ESP-IDF v4.4-dev-2313-gc69f0ec32 2nd stage bootloader I (49) boot: compile time 12:10:29 I (49) boot: chip revision: 3 I (49) boot_comm: chip revision: 3, min. bootloader chip revision: 0 I (56) boot.esp32c3: SPI Speed : 80MHz I (59) boot.esp32c3: SPI Mode : DIO I (63) boot.esp32c3: SPI Flash Size : 4MB I (67) boot: Enabling RNG early entropy source... I (71) boot: Partition Table: I (74) boot: ## Label Usage Type ST Offset Length I (80) boot: 0 nvs WiFi data 01 02 00009000 00005000 I (87) boot: 1 otadata OTA data 01 00 0000e000 00002000 I (93) boot: 2 app0 OTA app 00 10 00010000 00300000 I (100) boot: 3 spiffs Unknown data 01 82 00310000 000f0000 I (106) boot: End of partition table I (110) boot_comm: chip revision: 3, min. application chip revision: 0 I (116) esp_image: segment 0: paddr=00010020 vaddr=3c0a0020 size=1c070h (114800) map I (141) esp_image: segment 1: paddr=0002c098 vaddr=3fc8d000 size=02338h ( 9016) load I (143) esp_image: segment 2: paddr=0002e3d8 vaddr=40380000 size=01c40h ( 7232) load I (147) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=96fb4h (618420) map I (249) esp_image: segment 4: paddr=000c6fdc vaddr=40381c40 size=0b24ch ( 45644) load I (258) esp_image: segment 5: paddr=000d2230 vaddr=50000000 size=00010h ( 16) load I (262) boot: Loaded app from partition at offset 0x10000 I (263) boot: Disabling RNG early entropy source... |
1 条评论
191个成员聚集在这个小组
加入小组470 浏览 1 评论
1648 浏览 2 评论
642浏览 6评论
536浏览 5评论
515浏览 5评论
517浏览 4评论
507浏览 4评论
GMT+8, 2025-2-23 11:40 , Processed in 0.874735 second(s), Total 46, Slave 41 queries .
