在使用esp-idf-v4.4的库及esp32-c3-s32模组的情况下,遇到twai功能的两个GPIO2/GPIO3无数据波形的情况,有朋友遇到过吗?如何解决
void app_main(void) { twai_message_t message; esp_err_t err; //Initialize configuration structures using macro initializers twai_general_config_t g_config = TWAI_GENERAL_CONFIG_DEFAULT(TX_GPIO_NUM, RX_GPIO_NUM, TWAI_MODE_NORMAL); twai_timing_config_t t_config = TWAI_TIMING_CONFIG_500KBITS(); twai_filter_config_t f_config = TWAI_FILTER_CONFIG_ACCEPT_ALL(); //Install TWAI driver if (twai_driver_install(&g_config, &t_config, &f_config) == ESP_OK) { ESP_LOGI(EXAMPLE_TAG, "Driver installedn"); } else { ESP_LOGI(EXAMPLE_TAG, "Failed to install drivern"); return; } //Start TWAI driver if (twai_start() == ESP_OK) { ESP_LOGI(EXAMPLE_TAG, "Driver startedn"); } else { ESP_LOGI(EXAMPLE_TAG, "Failed to start drivern"); return; } message.identifier = 0xAAAA; message.extd = 1; message.data_length_code = 8; for (int i = 0; i < 8; i++) { message.data = 0x0A; } while(1) { //Queue message for transmission err = twai_transmit(&message, portMAX_DELAY); if (err == ESP_OK) { ESP_LOGI(EXAMPLE_TAG,"Message queued for transmissionn"); } else { ESP_LOGI(EXAMPLE_TAG,"Failed to queue message for transmissionn"); twai_clear_transmit_queue(); } vTaskDelay(pdMS_TO_TICKS(10000)); } vTaskDelete(NULL); } |
171个成员聚集在这个小组
加入小组350 浏览 0 评论
1196 浏览 1 评论
588浏览 6评论
484浏览 5评论
468浏览 5评论
467浏览 4评论
445浏览 4评论
GMT+8, 2024-12-29 14:46 , Processed in 1.152932 second(s), Total 75, Slave 59 queries .
